Component: Range Time of Flight (VL53L0X) (Light)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Light |
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed.
Detector
ChangeI2CAddress
ChangeI2CAddress |
Updates the I2C address of the sensor. | |
Address |
UpdateAddressReg |
0=Leave address register alone, 1=Update address register | |
Return |
Initialise |
Return |
ReadDistance
ReadDistance |
Read the current distance in mm. Returns -1 if the sensor timed out during the read operation. | |
Return |
ReadModel
ReadModel |
Collects the model number from the sensor | |
Return |
ReadRegister
ReadRegister |
A simple example showing a generic way to read a register using I2C. | |
Address |
Return |
ReadRegister16
ReadRegister16 |
Address |
Return |
ReadRevision
ReadRevision |
Collects the revision number from the sensor | |
Return |
WriteRegister
WriteRegister |
A simple example showing a generic way to write a register using I2C. | |
Address |
Data |
Return |
WriteRegister16
WriteRegister16 |
Address |
Data |
Return |
Please click here to download the component source project: FC_Comp_Source_RangeTOF_VL53L0X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RangeTOF_VL53L0X.fcfx
