Component: HTTP Fetch ( Comms)
| Author | MatrixTSL |
| Version | 0.1 |
| Category | Comms |
HTTP Fetch component
Component designed to request resources from an external HTTP server.
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Fetch.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Fetch.fcsx
HTTP
Example program showing how to retreive the HTML source of a HTTP URL.
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/example/fetchtest.txt
HTTP JSON Encoded
Example program showing how to retreive the HTML source of a HTTP URL. Here the source is encoded JSON data which we can parse through.
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/example/jsonfetchtest.txt
HTTP JSON Encoded Time and Date
Example program showing how to retreive the HTML source of a HTTP URL. Here the source is encoded JSON data which we can parse through. The data is created using a PHP script which allows for dynamic data such as the current time and date.
The HTML source is hosted at the following URL: http://www.flowcode.co.uk/example/jsonfetchtimedate.php
Please note the file type for the file below has been changed from .php to .txt to be allowed onto the Wiki.
Weather Example
Example program showcasing a number of components used together to collect data from a URL using fetch, before processing the data using the object helper and array helper components.
Fetch
| Fetch | |
| Start the process of fetching a resource from a web server | |
| sParams | |
| Parameters for the Fetch call | |
SetMacro
| SetMacro | |
| sMacro | |
SetURL
| SetURL | |
| Sets the URL for the Fetch call | |
| sURL | |
| Properties | |
| URL | |
| Call macro | |
