Component: GLCD (SSD1322) Parallel (Graphical Monochrome)
Revision as of 14:29, 1 March 2024 by Wiki bot (talk | contribs)
Version 1.3
Category Graphical Monochrome
GLCD (SSD1322) Parallel component
Graphical display component designed to work with the SSD1322 type monochrome displays. Compatible with 6800 and 8080 type 8-bit parallel displays.
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawCircle
Fc9-comp-macro.png DrawCircle
Fc9-u8-icon.png - BYTE Solid
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE Pixel_Colour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
SetShadeIntensity
Fc9-comp-macro.png SetShadeIntensity
Allows the shade intensity to be set allowing for up to 15 different greyscale levels. Range: 1-15 Default: 15
Fc9-u8-icon.png - BYTE Shade
Range: 1-15 / 1=Dim / 15 = Bright
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-conn-icon.png Display Settings
Fc9-type-21-icon.png Enable Delay
Time in micro seconds to wait before and after toggling the enable pin.
Fc9-type-16-icon.png Interface Type
Sets the display interface type, this wil lhave to match the gLCD hardware setting.
Fc9-type-5-icon.png CS
Chip select to address the first controller IC
Fc9-type-5-icon.png R/W / Write
6800 - Read / Write Selection Pin 8080 - Write Enable Pin
Fc9-type-5-icon.png Enable / Read
6800 - Enable Pin 8080 - Read Enable Pin
Fc9-type-5-icon.png Data/Command
Data / Command selection pin
Fc9-type-5-icon.png Reset
Display reset pin
Fc9-type-7-icon.png Use Port
Controls if the data is sent via an 8-bit port, significantly speeding up writes to the display.
Fc9-type-19-icon.png Data Port
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-conn-icon.png Simulation Mode
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1322.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1322.fcfx
