Component: Range Time of Flight (VL53L0X) (Light)
Revision as of 08:04, 23 September 2024 by MartinW (talk | contribs) (→‎Examples)
Author MatrixTSL
Category Light
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
ChangeI2CAddress
Fc9-comp-macro.png ChangeI2CAddress
Updates the I2C address of the sensor.
Fc9-bool-icon.png - BOOL UpdateAddressReg
0=Leave address register alone, 1=Update address register
Fc9-comp-macro.png Initialise
ReadDistance
Fc9-comp-macro.png ReadDistance
Read the current distance in mm. Returns -1 if the sensor timed out during the read operation.
Fc9-s16-icon.png - INT Return
ReadModel
Fc9-comp-macro.png ReadModel
Collects the model number from the sensor
ReadRegister
Fc9-comp-macro.png ReadRegister
A simple example showing a generic way to read a register using I2C.
ReadRegister16
Fc9-comp-macro.png ReadRegister16
ReadRevision
Fc9-comp-macro.png ReadRevision
Collects the revision number from the sensor
WriteRegister
Fc9-comp-macro.png WriteRegister
A simple example showing a generic way to write a register using I2C.
Fc9-u8-icon.png - BYTE Data
WriteRegister16
Fc9-comp-macro.png WriteRegister16
Fc9-u16-icon.png - UINT Data
Fc9-conn-icon.png Sensor Properties
Fc9-type-16-icon.png Range
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Fc9-conn-icon.png Simulation
Please click here to download the component source project: FC_Comp_Source_RangeTOF_VL53L0X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RangeTOF_VL53L0X.fcfx
