| Author
MatrixTSL
| Version
2.1
| Category
Graphical Library
Display Manager component
Version information
13, 2.0, 22-05-24, BR, Added text alignment options
14, 2.1, 14-06-24, BR, Renamed Button to Widget to better include things like sliders
Objects
The component can create the following objects.
- Object_Hidden - 0 - A hidden area with no graphics.
- Object_Rectangle - 1 - A simple rectangular box.
- Object_Line - 2 - A simple straight line.
- Object_Ellipse - 3 - A simple ellipse or circle.
- Object_EllipseFilled - 4 - A filled ellipse or circle.
- Object_RectangeFilled - 5 - A filled rectangular box.
Widgets
The component can also create the following interactive buttons and sliders.
- Widget_Hidden - 0 - A hidden area with no graphics.
- Widget_Rectangle - 1 - A rectangular box with a shadow.
- Widget_RoundedRectangle - 2 - A rounded rectangular box with a shadow.
- Widget_Ellipse - 3 - A simple ellipse or circle with a shadow.
- Widget_VSlider - 4 - A vertical slider with a square thumb.
- Widget_HSlider - 5 - A horizontal slider with a square thumb.
- Widget_VSlider_Round - 6 - A vertical slider with a round thumb.
- Widget_HSlider_Round - 7 - A horizontal slider with a round thumb.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Object_Rectangle or DisplayManager1::Widget_VSlider
Touch Repeat Rate for Button Widgets
The Touch Repeat Rate property applies to button based widgets and sets the frequency that a valid touch will be detected for a held button. This is similar to holding down a single key on a keyboard and acts to reduce the frequency of positive button detections when touching the button. For example if you had a button that incremented a value, without the repeat rate the value would increment much faster then anticipated in an uncontrollable manner. When no touch is detected it is recommended to call the NoTouch macro to clear the touch counters and allow a more responsive user experience.
Example of implementing touch repeat rate
An example showing how to use the display manager with a GLCd and a touch interface to create a full HMI.
Display Manager Demo
CheckForTouch
CheckForTouch
| Uses the X and Y coordinates from a touch sensor to check for Widget presses. Returns 0 for no Widgets pressed. Returns ID for a valid Widget press. Any touched slider Widgets will automatically move their thumb and value to the touch position.
- UINT
X
- UINT
Y
- UINT
ClearAll
ClearAll
| Removes all objects and Widgets from memory. Also clears the screen if required.
- BOOL
ClearScreen
| 0=Don't clear the screen, 1=Clear the screen
CreateObject
CreateObject
| Define a none touchable graphical object. Returns the Object ID.
- BYTE
ObjectType
| 0=Hidden, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
- UINT
X
| X Pixel Coordinate
- UINT
Y
| Y Pixel Coordinate
- UINT
Width
| Pixel Width or X Radius
- UINT
Height
| Pixel Height or Y Radius
- BYTE
Theme
| Theme index to use to draw the object
- BOOL
DrawObject
| 0=Do not draw object yet, 1=Draw object now (Does not apply to hidden objects)
- UINT
CreateWidget
CreateWidget
| Define an interactive Widget or slider. Returns the Widget ID.
- BYTE
WidgetType
| 0=WidgetHidden, 1=WidgetRect, 2=WidgetRoundedRect, 3=WidgetEllipse, 4=VSlider, 5=HSlider, 6=VSliderRound, 7=HSliderRound
- UINT
X
| X Pixel Coordinate
- UINT
Y
| Y Pixel Coordinate
- UINT
Width
- UINT
Height
- BYTE
Theme
| Theme index to use to draw the Widget
- BOOL
DrawWidget
| 0=Do not draw Widget yet, 1=Draw Widget now (Does not apply to hidden widgets)
- UINT
DrawAll
DrawAll
| Redraws all of the defined Objects and Widgets. Doesn't draw text, this is done using the SetText macro.
DrawItem
DrawItem
| Draws a single object or Widget onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
- UINT
ID
| Unique ID of the Object or Widget
GetLastTouchID
GetLastTouchID
| Gets the ID of the last Widget that returned a valid press via the CheckForTouch macro. Returns 0 for no valid touch recorded.
- INT
GetSliderValue
GetSliderValue
| Reads the value of one of the sliders ranging between 0 and 1.
- UINT
WidgetID
- FLOAT
| Initialises the object and Widget control variables and sets up the default themes.
ModifyPosition
ModifyPosition
| Moves an existing object or Widget to absolute coordinates on the screen.
- UINT
ID
| Unique ID of the object or Widget
- INT
X
- INT
Y
- BOOL
Relative
| 0=Absolute Positioning, 1=Relative Positioning
ModifyScale
ModifyScale
| Changes the width and height of the selected Object or Widget.
- UINT
ID
- UINT
Width
- UINT
Height
ModifyTheme
ModifyTheme
| Changes the theme index of the selected Object or Widget.
- UINT
ID
- BYTE
Theme
| Theme index of the Widget or object
NoTouch
NoTouch
| Called when no touch is present, Allows the repeat rate counter to be cleared allowing for better responses to fast touches.
OverrideObjectTheme
OverrideObjectTheme
| Overrides the colour of an object theme, used by the draw object macro.
- BYTE
ThemeIndex
| Index of the object colour theme
- BYTE
FG_R
| Foreground colour channel value
- BYTE
FG_G
- BYTE
FG_B
- BYTE
BG_R
| Background colour channel value
- BYTE
BG_G
- BYTE
BG_B
OverrideWidgetTheme
OverrideWidgetTheme
| Overrides the colour of a Widget theme, used by the draw Widget macro.
- BYTE
ThemeIndex
- BYTE
FG_R
- BYTE
FG_G
- BYTE
FG_B
- BYTE
BG_R
- BYTE
BG_G
- BYTE
BG_B
- BYTE
HL_R
| Highlight colour channel value
- BYTE
HL_G
- BYTE
HL_B
- BYTE
LL_R
| Lowlight colour channel value
- BYTE
LL_G
- BYTE
LL_B
SetSliderValue
SetSliderValue
| Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
- UINT
WidgetID
- FLOAT
Value
| Range: 0 to 1
- BOOL
RedrawSlider
| 0=Do not redraw, 1=Redraw
SetTextFloat
SetTextFloat
| Draws a numerical value onto an object or Widget location. Useful for displaying, value statistics. Drawn using the object themes.
- UINT
ID
| Unique identifier of object or Widget.
| [[File:]] -
Number
- BYTE
NumDP
| Number of decimal points to display
- STRING
Unit
| Unit string to add after the numeric value. e.g. "g" or "s"
- BYTE
Font
- BYTE
HAlignment
| 0=Left, 1=Center, 2=Right
- BYTE
VAlignment
| 0=Top, 1=Middle, 2=Bottom
- BYTE
Theme
| Object theme index to control the colour of the text
- BOOL
Transparent
| 0=Background Colour Drawn, 1=Don't Draw Background Colour
SetTextLabel
SetTextLabel
| Draws a single line of text onto an object or Widget location. Useful for labelling Widgets such as buttons or having name, value statistics. Drawn using the object themes.
- UINT
ID
- STRING
Text
- BYTE
Font
- BYTE
HAlignment
- BYTE
VAlignment
- BYTE
Theme
- BOOL
Transparent
SetTextNumber
SetTextNumber
- UINT
ID
| [[File:]] -
Number
- STRING
Unit
- BYTE
Font
- BYTE
HAlignment
- BYTE
VAlignment
- BYTE
Theme
- BOOL
Transparent
Graphical Display
| Graphical Display to draw our objects on
DM Library
| Display Manager compatible GLCD library component. e.g. Bitmap drawer components.
Ram Usage Bytes
| The calculated number of bytes of RAM required by the display manager.
Text Align Offset
| Number of pixels to move away from an edge when calling SetText
Objects
Max Objects
| The total number of primitive objects allowed on the screen at once. Sets the size of the RAM buffers used to track the various screen elements. Each object requires 10 bytes of RAM to stores things like size, location and type.
Object Theme Count
| Sets the number of themes available when drawing primitive objects. Each object theme requires 6 bytes of RAM to store the colour channels.
Theme 0
Foreground
| Foreground colour of the theme
Background
| Background colour of the theme
Theme 1
Foreground
Background
Theme 2
Foreground
Background
Widgets
Max Widgets
| The total number of touchable interactibe objects allowed on the screen at once e.g. Widgets and sliders. Sets the size of the RAM buffers used to track the various screen elements Each Widget requires 18 bytes of RAM to stores things like size, location, value and type.
Touch Repeat Rate
| Sets the period for touch repeats in terms of calls of the CheckForTouch macro. Widgets will only register a repeat touch after x calls if continually held down. Sliders will always register a touch. The touch count can be cleared using the NoTouch macro if no touch is detected.
Slider Thumb Width
| Number of pixels wide to make a slider thumb marker,
Slider Center Line Thickness
| Number of pixels thick to draw the slider central line
Widget Theme Count
| Sets the number of themes available for drawng Widgets. Each Widget theme requires 12 bytes of RAM to store the colour channels.
Theme 0
Foreground
Background
Highlight
| Highlight colour of the theme
Lowlight
| Lowlight colour of the theme
Theme 1
Foreground
Background
Highlight
Lowlight
