Component: Display Manager (Graphical Library)
Author MatrixTSL
Version 2.1
Category Graphical Library
Display Manager component
Version information
13, 2.0, 22-05-24, BR, Added text alignment options
14, 2.1, 14-06-24, BR, Renamed Button to Widget to better include things like sliders
15, 2.1, 26-07-24, BR, Added SetTextFloat and AddTextNumber macros
16, 2.1, 29-07-24, BR, Renamed Themes to ObjectThemes and WidgetThemes
Objects
The component can create the following objects.
  • Object_Hidden - 0 - A hidden area with no graphics.
  • Object_Rectangle - 1 - A simple rectangular box.
  • Object_Line - 2 - A simple straight line.
  • Object_Ellipse - 3 - A simple ellipse or circle.
  • Object_EllipseFilled - 4 - A filled ellipse or circle.
  • Object_RectangeFilled - 5 - A filled rectangular box.
Widgets
The component can also create the following interactive buttons and sliders.
  • Widget_Hidden - 0 - A hidden area with no graphics.
  • Widget_Rectangle - 1 - A rectangular box with a shadow.
  • Widget_RoundedRectangle - 2 - A rounded rectangular box with a shadow.
  • Widget_Ellipse - 3 - A simple ellipse or circle with a shadow.
  • Widget_VSlider - 4 - A vertical slider with a square thumb.
  • Widget_HSlider - 5 - A horizontal slider with a square thumb.
  • Widget_VSlider_Round - 6 - A vertical slider with a round thumb.
  • Widget_HSlider_Round - 7 - A horizontal slider with a round thumb.
The type can be entered by using the component's public constants. Begin with the Display Manager handle name followed by :: and the list of the public variables will be displayed.
For example... DisplayManager1::Object_Rectangle or DisplayManager1::Widget_VSlider
Touch Repeat Rate for Button Widgets
The Touch Repeat Rate property applies to button based widgets and sets the frequency that a valid touch will be detected for a held button. This is similar to holding down a single key on a keyboard and acts to reduce the frequency of positive button detections when touching the button. For example if you had a button that incremented a value, without the repeat rate the value would increment much faster then anticipated in an uncontrollable manner. When no touch is detected it is recommended to call the NoTouch macro to clear the touch counters and allow a more responsive user experience.
Example of implementing touch repeat rate
An example showing how to use the display manager with a GLCd and a touch interface to create a full HMI.
FC6 Icon.png Display Manager Demo
CheckForTouch
Fc9-comp-macro.png CheckForTouch
Uses the X and Y coordinates from a touch sensor to check for Widget presses. Returns 0 for no Widgets pressed. Returns ID for a valid Widget press. Any touched slider Widgets will automatically move their thumb and value to the touch position.
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
ClearAll
Fc9-comp-macro.png ClearAll
Removes all objects and Widgets from memory. Also clears the screen if required.
Fc9-bool-icon.png - BOOL ClearScreen
0=Don't clear the screen, 1=Clear the screen
CreateObject
Fc9-comp-macro.png CreateObject
Define a none touchable graphical object. Returns the Object ID.
Fc9-u8-icon.png - BYTE ObjectType
0=Hidden, 1=Rect, 2=Line, 3=Ellipse, 4=FilledEllipse, 5=FilledRect
X Pixel Coordinate
Y Pixel Coordinate
Fc9-u16-icon.png - UINT Width
Pixel Width or X Radius
Fc9-u16-icon.png - UINT Height
Pixel Height or Y Radius
Fc9-u8-icon.png - BYTE ObjectTheme
Theme index to use to draw the object
Fc9-bool-icon.png - BOOL DrawObject
0=Do not draw object yet, 1=Draw object now (Does not apply to hidden objects)
CreateWidget
Fc9-comp-macro.png CreateWidget
Define an interactive Widget or slider. Returns the Widget ID.
Fc9-u8-icon.png - BYTE WidgetType
0=WidgetHidden, 1=WidgetRect, 2=WidgetRoundedRect, 3=WidgetEllipse, 4=VSlider, 5=HSlider, 6=VSliderRound, 7=HSliderRound
X Pixel Coordinate
Y Pixel Coordinate
Fc9-u8-icon.png - BYTE WidgetTheme
Theme index to use to draw the Widget
Fc9-bool-icon.png - BOOL DrawWidget
0=Do not draw Widget yet, 1=Draw Widget now (Does not apply to hidden widgets)
DrawAll
Fc9-comp-macro.png DrawAll
Redraws all of the defined Objects and Widgets. Doesn't draw text, this is done using the SetText macro.
DrawItem
Fc9-comp-macro.png DrawItem
Draws a single object or Widget onto the display without clearing the display. Doesn't draw a textfield component, this is done using the SetObjectText macro.
Fc9-u16-icon.png - UINT ID
Unique ID of the Object or Widget
GetLastTouchID
Fc9-comp-macro.png GetLastTouchID
Gets the ID of the last Widget that returned a valid press via the CheckForTouch macro. Returns 0 for no valid touch recorded.
Fc9-s16-icon.png - INT Return
GetSliderValue
Fc9-comp-macro.png GetSliderValue
Reads the value of one of the sliders ranging between 0 and 1.
Fc9-u16-icon.png - UINT WidgetID
Fc9-comp-macro.png Initialise
Initialises the object and Widget control variables and sets up the default themes.
ModifyPosition
Fc9-comp-macro.png ModifyPosition
Moves an existing object or Widget to absolute coordinates on the screen.
Unique ID of the object or Widget
Fc9-s16-icon.png - INT X
Fc9-s16-icon.png - INT Y
Fc9-bool-icon.png - BOOL Relative
0=Absolute Positioning, 1=Relative Positioning
ModifyScale
Fc9-comp-macro.png ModifyScale
Changes the width and height of the selected Object or Widget.
ModifyTheme
Fc9-comp-macro.png ModifyTheme
Changes the theme index of the selected Object or Widget.
Fc9-u8-icon.png - BYTE Theme
Theme index of the Widget or object
NoTouch
Fc9-comp-macro.png NoTouch
Called when no touch is present, Allows the repeat rate counter to be cleared allowing for better responses to fast touches.
OverrideObjectTheme
Fc9-comp-macro.png OverrideObjectTheme
Overrides the colour of an object theme, used by the draw object macro.
Fc9-u8-icon.png - BYTE ThemeIndex
Index of the object colour theme
Fc9-u8-icon.png - BYTE FG_R
Foreground colour channel value
Fc9-u8-icon.png - BYTE FG_G
Fc9-u8-icon.png - BYTE FG_B
Fc9-u8-icon.png - BYTE BG_R
Background colour channel value
Fc9-u8-icon.png - BYTE BG_G
Fc9-u8-icon.png - BYTE BG_B
OverrideWidgetTheme
Fc9-comp-macro.png OverrideWidgetTheme
Overrides the colour of a Widget theme, used by the draw Widget macro.
Fc9-u8-icon.png - BYTE HL_R
Highlight colour channel value
Fc9-u8-icon.png - BYTE HL_G
Fc9-u8-icon.png - BYTE HL_B
Fc9-u8-icon.png - BYTE LL_R
Lowlight colour channel value
Fc9-u8-icon.png - BYTE LL_G
Fc9-u8-icon.png - BYTE LL_B
SetSliderValue
Fc9-comp-macro.png SetSliderValue
Sets the value of one of the sliders and optionally redraws the slider to reflect the value change.
Range: 0 to 1
Fc9-bool-icon.png - BOOL RedrawSlider
0=Do not redraw, 1=Redraw
SetTextFloat
Fc9-comp-macro.png SetTextFloat
Draws a numerical value onto an object or Widget location. Useful for displaying, value statistics. Drawn using the object themes.
Unique identifier of object or Widget.
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE NumDP
Number of decimal points to display
Fc9-string-icon.png - STRING Unit
Unit string to add after the numeric value. e.g. "g" or "s"
Fc9-u8-icon.png - BYTE Font
Fc9-u8-icon.png - BYTE HAlignment
0=Left, 1=Center, 2=Right
Fc9-u8-icon.png - BYTE VAlignment
0=Top, 1=Middle, 2=Bottom
Object theme index to control the colour of the text
Fc9-bool-icon.png - BOOL Transparent
0=Background Colour Drawn, 1=Don't Draw Background Colour
SetTextLabel
Fc9-comp-macro.png SetTextLabel
Draws a single line of text onto an object or Widget location. Useful for labelling Widgets such as buttons or having name, value statistics. Drawn using the object themes.
SetTextNumber
Fc9-comp-macro.png SetTextNumber
[[File:]] - Number
Fc9-type-16-icon.png Graphical Display
Graphical Display to draw our objects on
Fc9-type-16-icon.png DM Library
Display Manager compatible GLCD library component. e.g. Bitmap drawer components.
Fc9-type-21-icon.png Ram Usage Bytes
The calculated number of bytes of RAM required by the display manager.
Fc9-type-21-icon.png Text Align Offset
Number of pixels to move away from an edge when calling
Fc9-conn-icon.png Objects
Fc9-type-21-icon.png Max Objects
The total number of primitive objects allowed on the screen at once. Sets the size of the RAM buffers used to track the various screen elements. Each object requires 10 bytes of RAM to stores things like size, location and type.
Fc9-type-16-icon.png Object Theme Count
Sets the number of themes available when drawing primitive objects. Each object theme requires 6 bytes of RAM to store the colour channels.
Fc9-conn-icon.png Object Theme 0
Fc9-type-1-icon.png Foreground
Foreground colour of the theme
Fc9-type-1-icon.png Background
Background colour of the theme
Fc9-conn-icon.png Object Theme 1
Fc9-conn-icon.png Object Theme 2
Fc9-conn-icon.png Widgets
Fc9-type-21-icon.png Max Widgets
The total number of touchable interactibe objects allowed on the screen at once e.g. Widgets and sliders. Sets the size of the RAM buffers used to track the various screen elements Each Widget requires 18 bytes of RAM to stores things like size, location, value and type.
Fc9-type-21-icon.png Touch Repeat Rate
Sets the period for touch repeats in terms of calls of the CheckForTouch macro. Widgets will only register a repeat touch after x calls if continually held down. Sliders will always register a touch. The touch count can be cleared using the NoTouch macro if no touch is detected.
Fc9-type-21-icon.png Slider Thumb Width
Number of pixels wide to make a slider thumb marker,
Fc9-type-21-icon.png Slider Center Line Thickness
Number of pixels thick to draw the slider central line
Fc9-type-16-icon.png Widget Theme Count
Sets the number of themes available for drawng Widgets. Each Widget theme requires 12 bytes of RAM to store the colour channels.
Fc9-conn-icon.png Widget Theme 0
Fc9-type-1-icon.png Highlight
Highlight colour of the theme
Fc9-type-1-icon.png Lowlight
Lowlight colour of the theme
Fc9-conn-icon.png Widget Theme 1
