Component: Servo Motor Controller (Mechatronics)
Revision as of 11:10, 29 January 2025 by MartinW (talk | contribs) (Examples)
Version 2.1
Category Mechatronics
Servo Motor Controller component
Can control up to eight standard PWM driven servo's. Supports 8-bit and 16-bit movement resolutions. 'Servo Object' properties allow you to connect the controller to on-screen simulations using the "Servo Motor" component and its derivatives.
Example showing how to control three servos using AutoMoveToPosion, MoveTopposition & SetPosition component macros.
Controlling Servos Example.fcfx
Example using BL0162 Servo controller for BL0055 Arduino Shield
Samples the Port D8-D13 (portB) switches and moves the servo motors based on the input states.
D8 increments motor 0, D9 decrements motor on channel 0.
D10 increments motor 1, D11 decrements motor on channel 1.
D12 increments motor 3, D13 decrements motor on channel 2.
Connections:
Servo Board Port D0-D2.
Switch Board Port D8 - D13
LCD A0 to A5 (PortC)
BL0162 Servos Example for BL0055
AutoMoveToAngle
AutoMoveToAngle
Automatically moves towards the new angle at a fixed rate determined by the AutoMoveSpeed. AutoMove not currently supported by ESP32.
- BYTE Channel
The channel to assign the new position. Range: 0-7
- BYTE Angle
Angle in degrees, Range 0 to calibration angle
AutoMoveToPosition
AutoMoveToPosition
Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed. AutoMove not currently supported by ESP32.
- BYTE Channel
- BYTE Position
Position to automatically move to. Range: 0-255
AutoMoveToPositionInt
Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed. AutoMove not currently supported by ESP32.
- BYTE Channel
- UINT Position
Position to automatically move to. Range: 0-65535
DisableServo
DisableServo
Disables a servo channel effectivly disabling the motor.
- BYTE Channel
The channel to set the position for. First channel is zero.
EnableServo
EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
- BYTE Channel
Sets up the servo motor interrupts
IsAutoMoving
IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete.
IsServoAutoMoving
IsServoAutoMoving
Is the AutoMoveToPosition movement complete for a specific servo output. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
- BYTE Channel
Servo Motor Output Range: 0-7
MoveToAngle
MoveToAngle
Moves a single step towards the new angle, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
- BYTE Channel
- BYTE Angle
- BOOL Return
MoveToPosition
MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
- BYTE Channel
- BYTE Position
Target position to move towards. Range: 0-255
MoveToPositionInt
MoveToPositionInt
- BYTE Channel
- UINT Position
Target position to move towards. Range: 0-65535
SetAngle
SetAngle
Moves the motor straight to the specified angle. Uses the angle property to calculate the correct amount to move.
- BYTE Channel
- BYTE Angle
SetAutoMoveSpeed
SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is shown in the Servo_Period_Multiplier property.
- BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
SetAutoMoveSpeedInt
SetAutoMoveSpeedInt
- UINT Speed
SetPosition
SetPosition
Moves directly to the specified position with no interpolation.
- BYTE Channel
- BYTE Position
Position to jump to. Range: 0-255
SetPositionInt
SetPositionInt
Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
- BYTE Channel
- UINT Position
Position to jump to. Range: 0-65535
SetTrim
SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
- BYTE Channel
- BYTE Trim
Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
Channels (1 - 8)
Set the number of servo's that you need to control. Value from 1 to 8.
Resources
Peripherals
Lists the internal peripherals of the MCU used by the component. When the servo motor is initialised you will not be able to use the listed peripherals for other functionality.
Pulse Width
Minimum (us)
Shortest pulse width that will be used.
Maximum (us)
Longest pulse width used for the PWM signals.
Channel 0
Pin on which to output PWM for the servo motor.
Angle
Angle 0
Range of movement in the servo motor to calibrate the Angle component macros. Can be found by measuring the angle between position 0 and position 255.
Trim
Trim Mode
Trim 0
Trim the pulse width for this channel. Use this to trim the positioning of two servos so that similar input values will produce the same degree of movement.
Servo Object 0
Drag a servo motor component onto the System Panel, and then select it here, to create an on screen simulation of the way that your flowchart moves the servo's. Servo motors should be based on the 'Servo Motor Base' component, or use a custom component set to responf to 'User.Notify' events (ID = n/a, Data = Position (0-127)).
Please click here to download the component source project: FC_Comp_Source_Servo_Controller.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Servo_Controller.fcfx
