Component: Switch (Controls)
| Author | Steve Tandy |
| Category | Controls |
Switch component
A 2d switch component.
FREE
The polarity setting in switch properties determines how the corresponding bit in the input variable responds when the switch changes state.
This applies only when using switch functions and not when using input command icons.
- Active High Polarity
When the switch is closed, the voltage on the pin transitions from 0V to the positive supply voltage (either 3.3V or 5V, depending on the microcontroller).
As a result, the corresponding bit in the input variable changes from 0 to 1.
A pull-down resistor is required to ensure the pin stays at 0V when the switch is open.
If using two resistors (as shown in the image above), they provide protection in case the pin is mistakenly set as an output while the switch is pressed.
- Active Low Polarity
When the switch is closed, the voltage on the pin transitions from the positive supply voltage to 0V.
The corresponding bit in the input variable changes from 0 to 1.
A pull-up resistor is required to ensure the pin stays at the positive supply voltage when the switch is open.
If using two resistors(as shown in the image above), they provide protection if the pin is mistakenly set as an output while the switch is pressed.
The resistors are required for correct operation because when a microcontroller's input pin is essentially connected to nothing it will pick up noise in the environment and provide inconsistent readings.
This state is referred to as floating i.e. the pin is floating. To test this remove the resistors (if possible) and touch the unconnected pin with your finger the output LED from the example file above will toggle on and off at high speed.
Any values of resistor can be used but it is important to keep the smaller resistor at least 10X smaller then the larger resistor to ensure that the pressed state provides at least 0.91% of the required pressed state voltage.
For example a active high switch circuit using 1K and 10K resistors should pull up to about 4.54V when the switch is pressed.
(5V / 11K) * 10K = 4.54545V
| GetState | |
| Reads the state of the switch (true = on, false = off) | |
| SetState | |
| Sets the switch to be on or off. | |
| bState | |
| The new state of the switch (true=on, false=off) | |
| Properties | |
| State | |
| Style | |
| Type | |
| On Label | |
| Off Label | |
| Background Colour | |
| Connections | |
| Simulations | |
