Component: Potentiometer (Analog Input)
| Category | Analog Input |
Potentiometer component
Please click here to download the component source project: FC_Comp_Source_Potentiometer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Potentiometer.fcfx
No detailed description exists yet for this component test example file
Using Fixed Voltage Reference
An example of a 0 to 1023 mV meter with a resolution of 1mv.
A PIC16F15324 is used since it has a Fixed Voltage Reference (FVR) register.
Bit0 and bit1 determine what the FVR is set at.
A line of C code is added to set the FVR to a gain of x1 = FVR of 1.024V:
FVRCON = 0b11000001;
With this setting, the Int value from ADC directly proportional voltage in mV.
E.g. a value of 732 = 732mV
Binary is used to make reading values a lot easier.
From the datasheet:
If you wanted to change the fixed voltage reference to 2.048V
Then change bit0 and bit1 of the C code to FVRCON = 0b11000010;
Filtering ADC Inputs
Analogue Inputs Window
The Analogue inputs window available from the View ribbon, allows you to see the values for all of the analogue inputs which are active in your program. They can also be manually altered by dragging the mouse along one of the sliders.
Data Recorder
GetAverageByte
| GetAverageByte | |
| Read the ADC as a byte | |
| NumSamples | |
| DelayUs | |
GetAverageInt
| GetAverageInt | |
| Read the ADC at full bit depth | |
| NumSamples | |
| DelayUs | |
GetByte
| GetByte | |
GetInt
| GetInt | |
GetString
| GetString | |
| Reads the ADC as a direct voltage | |
GetVoltage
| GetVoltage | |
