Component: GLCD (ST7567) SPI NOBUFF (Graphical Monochrome)
Revision as of 08:57, 27 April 2026 by Wiki bot (talk | contribs)
Version 1.5
Category Graphical Monochrome
GLCD (ST7567) SPI NOBUFF component
Graphical display component designed to work with the ST7567 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work Not for public release.
Version information
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawArc
Fc9-comp-macro.png DrawArc
Draws an arc either as an outline or as a filled object.
Center X coordinate
Center Y coordinate
Radius, distance of edge from the centre coordinates
Fc9-f32-icon.png - FLOAT StartAngle
Angle to start drawing, in degrees
Fc9-f32-icon.png - FLOAT EndAngle
Angle to end drawing, in degrees
Fc9-u16-icon.png - UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
Fc9-u8-icon.png - BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
Fc9-comp-macro.png DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
Fc9-u16-icon.png - UINT X0
Start X coordinate
Fc9-u16-icon.png - UINT Y0
Start Y coordinate
Fc9-u16-icon.png - UINT CX
Control point X coordinate
Fc9-u16-icon.png - UINT CY
Control point Y coordinate
Fc9-u16-icon.png - UINT X2
End X coordinate
Fc9-u16-icon.png - UINT Y2
End Y coordinate
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
Fc9-comp-macro.png DrawCircle
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
DrawRectangle
Fc9-comp-macro.png DrawRoundedRectangle
Draws a rectangle with rounded corners
Goto_XY
Fc9-comp-macro.png Goto_XY
Fc9-u8-icon.png - BYTE X
Fc9-u8-icon.png - BYTE Y
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
0=White, 1=Black
Write_Command
Fc9-comp-macro.png Write_Command
Fc9-u8-icon.png - BYTE Command
Write_Data
Fc9-comp-macro.png Write_Data
Fc9-u8-icon.png - BYTE data
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-5-icon.png Data Pin
Fc9-type-5-icon.png Clock Pin
Fc9-type-5-icon.png A0
Fc9-type-5-icon.png CS
Chip select pin
Fc9-type-5-icon.png Reset
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-type-21-icon.png Bytes Required
Number of bytes required in program memory to store the selected font.
Fc9-type-21-icon.png Character Spacing
Sets the number of blank pixels between each character when printing text.
Fc9-type-21-icon.png Space Width
Fc9-type-16-icon.png LCDVersion
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Display Type
Fc9-type-16-icon.png Physical Orientation
Fc9-type-15-icon.png Component Label Scale
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7567_SPI_NoBuffer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7567_SPI_NoBuffer.fcfx
