Component: GLCD Base (Graphical Library)
Revision as of 14:13, 22 October 2025 by Wiki bot (talk | contribs)
Version 35.0
Category Graphical Library
GLCD Base component
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation. Suitable for inheriting to simplify the creation of further graphical LCD components.
Version information
33, 3.1, 13-06-24, BR, Added user selectable simulated mask for round displays
34, 3.1, 17-07-24, MW, Fixed bug where Arc is not displyed when Resolution is 0
35, 35, 17-07-24, MW, Added an additioanl font count of 4
35, 35, 17-07-24, MW, Changed a variable type to allow larger font sizes
Font sizes
Standard Fonts
0 = Normal
1 = 2 x Width
2 = 2 x Width and 2 x Height
3 = 2 x Height
Extended Fonts
4 = 2 x Width and 3 x Height
5 = 2 x Width and 4 x Height
6 = 2 x Width and 5 x Height
7 = 2 x Width and 6 x Height
8 = 3 x width
9 = 3 x Width and 2 x Height
10 = 3 x Width and 3 x Height
11 = 3 x Width and 4 x Height
12 = 3 x Width and 5 x Height
13 = 3 x Width and 6 x Height
14 = 4 x width
15 = 4 x Width and 2 x Height
16 = 4 x Width and 3 x Height
17 = 4 x Width and 4 x Height
18 = 4 x Width and 5 x Height
19 = 4 x Width and 6 x Height
20 = 5 x width
21 = 5 x Width and 2 x Height
22 = 5 x Width and 3 x Height
23 = 5 x Width and 4 x Height
24 = 5 x Width and 5 x Height
25 = 5 x Width and 6 x Height
26 = 6 x width
27 = 6 x Width and 2 x Height
28 = 6 x Width and 3 x Height
29 = 6 x Width and 4 x Height
30 = 6 x Width and 5 x Height
31 = 6 x Width and 6 x Height
EBM001 Basic Example
EBM001 gLCD Example File
FC6 Icon.png EBM001 Example
EBM001 Maze Builder
FC6 Icon.png Maze Builder gLCD
FC6 Icon.png 3D Manipulations
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DrawArc
Fc9-comp-macro.png DrawArc
Draws an arc either as an outline or as a filled object.
Center X coordinate
Center Y coordinate
Radius, distance of edge from the centre coordinates
Fc9-f32-icon.png - FLOAT StartAngle
Angle to start drawing, in degrees
Fc9-f32-icon.png - FLOAT EndAngle
Angle to end drawing, in degrees
Fc9-u16-icon.png - UINT Resolution
Number of lines to draw from the center to the outer edge
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
Fc9-u8-icon.png - BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
Fc9-comp-macro.png DrawCircle
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
Fc9-comp-macro.png DrawRoundedRectangle
Draws a rectangle with rounded corners
FastPlot
Fc9-comp-macro.png FastPlot
Sets a pixel with the current foreground colour at current pixel location.
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontByte
Fc9-comp-macro.png ReadFontByte
Gets a byte from the selected embedded ASCII font data.
ASCII character for example 'A' or 65
Fc9-u16-icon.png - UINT ByteIndex
Font column Ranging 0-4
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
SetDisplayOrientation
SetExternalFont
Fc9-comp-macro.png SetExternalFont
Allows one of the default external font files to be switched out for a different font file.
Range: 0 to (FontCount - 1)
New font filename
Fc9-u8-icon.png - BYTE CharacterSpacing
Number of pixel columns to use between each character
Fc9-u8-icon.png - BYTE SpaceWidth
Number of pixel columns to use for a space character
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Window
Fc9-comp-macro.png Window
Specifies a specific window in the pixels to draw to.
Fc9-conn-icon.png Dimensions
Fc9-type-21-icon.png Pixel Width
Fc9-type-21-icon.png Pixel Height
Fc9-conn-icon.png Colour
Fc9-type-1-icon.png Foreground Colour
Specifies the initial foreground colour for shapes and text.
Fc9-conn-icon.png Bit Depth
Fc9-type-21-icon.png Colour Bit Depth
Fc9-type-21-icon.png Red Bit Depth
Fc9-type-21-icon.png Green Bit Depth
Fc9-type-21-icon.png Blue Bit Depth
Fc9-conn-icon.png Fonts
Fc9-type-7-icon.png External Fonts
Defines how fonts are stored when compiled to a microcontroller. No - Font data is stored in the microcontroller ROM. Yes - Font data is stored externally on a file source such as an SD card.
Fc9-conn-icon.png Font 0
Fc9-type-10-icon.png BinaryFilename
Fc9-type-21-icon.png Bytes Required
Number of bytes required in program memory to store the selected font.
Fc9-type-21-icon.png Character Spacing
Sets the number of blank pixels between each character when printing text.
Fc9-conn-icon.png Simulation Mode
Fc9-type-7-icon.png Show Background Elements
Show or hide features like the title and background.
Fc9-type-11-icon.png User Label Text
Text to display
Fc9-type-15-icon.png Component Label Scale
Fc9-type-16-icon.png Display Type
Fc9-type-7-icon.png Embed Font Set
Specifies if the font set is included with the embedded downloadable code. Some display types have in an built font and text functions so the embedded font set can be disabled to reduce code overhead. For other display types the embedded font data should be enable to allow the print functions to work correctly.
Fc9-type-7-icon.png Embed Font Width
Fc9-type-21-icon.png Num Parents
Number of parent levels to jump up to get the auto title name. For most GLCDs it will be 1. For most Alpha LCDs it will be 2.
Fc9-type-7-icon.png Show GLCD Icon
Show the GLCD connectivity icon, Set to Yes for GLCDs and No for other none standard things e.g. Alphanumeric LCDs.
Fc9-type-21-icon.png TouchHandler
Fc9-type-16-icon.png Physical Orientation
Fc9-type-7-icon.png AutoRefresh
Fc9-type-7-icon.png Round Mask
Allows a round mask to be applied allowing a circular display to be simulated.
Fc9-type-7-icon.png Export Binary Fonts
Allows all selected fonts to be exported as a binary format that can be loaded from an SD card. When set to yes loops through all selected fonts and outputs .bin files into the project directory. May take some time to complete, resets back to no when complete.
Fc9-type-7-icon.png Export All Fonts
Please click here to download the component source project: FC_Comp_Source_GLCD_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_base.fcfx
