Component: Switch Array (Slide) (Switches)
| Author | MatrixTSL |
| Version | 13.13 |
| Category | Switches |
Switch Array (Slide) component
An array of up to eight slide switches. In embedded mode each switch is connected to a single pin of the specified port.
Version information
Library Version, Component Version, Date, Author, Info 9, 9.0, 25-06-24, MW, Added option to customise appearance of individual or all switches 10, 10.0, 26-06-24, MW, Corrected switch and component name bug 12, 11.0, 16-04-25, MW, Corrected bug when sim stopped Switch changed from on to off, but pin remained at VCC 12, 11.0, 16-04-25, MW, Added properties of Ev_PropertiesEX to Ev_Initialise 12, 11.0, 16-04-25, MW, Fixed bug so individual customisation now works 12, 11.0, 16-04-25, MW, Created a new component icon 13, 13.0, 25-09-25, MW, updated to brig in-line with Switch Array Push
Here is an example Flowcode program to read the values of a switch array.
Switch Array
(5V / 11K) * 10K = 4.54545V
ReadAll
| ReadAll | |
| Reads all of the switches at once, returning a byte containing one bit per switch. | |
ReadState
| ReadState | |
| Read the state of the switch at the given index. | |
| Index | |
| The switch to read the status of. | |
WaitUntilHigh
| WaitUntilHigh | |
| Pause the program until the switch at the given index is turned on. | |
| Index | |
| Index of the switch to wait for. | |
WaitUntilLow
| WaitUntilLow | |
| Index | |
Please click here to download the component source project: FC_Comp_Source_Switch_Array_Slide_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Array_Slide_2dgi.fcfx
