Component: GLCD Free (ST7567) SPI (Graphical Monochrome)
Version 1.5
Category Graphical Monochrome
GLCD Free (ST7567) SPI component
Graphical display component designed to work with the ST7567 type monochrome displays. Transfers data using a 4-wire SPI interface, cannot read back so pixel based routines won't work Not for public release.
Version information
The MQTT component requires connection to a Network Comms component via the "Network Component" property, to provide the bridge for simulated TCP/IP communication.
The Network Comms component can then be linked to an embedded TCP/IP component to provide embedded TCP/IP support.
Here is a typical setup for using MQTT on a Raspberry Pi.
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
SCADA BBC TEMPERATURES
Publish
Raspberry Pi
Here we have an embedded Raspberry Pi project connected to an I2C Sensor, the sensor is sampled and the data is published to a MQTT server.
RPI3 MQTT IOT EBM016
ESP8266 Module
Here we have an embedded project using an ESP8266 wifi module, an analogue input is sampled and the data is published to a MQTT server.
MQTT IOT ESP8266
Subscribe
ESP8266 Module
Here we subscribe to a topic and receive it back into Flowcode embedded using an ESP8266 module.
Subscribe ESP8266 MQTT
Flowcode App Developer
Here we subscribe to a topic and receive it back into Flowcode App Developer.
Subscribe App Developer MQTT
Making your own Raspberry Pi based MQTT Broker
Click here for instructions on creating your own Raspberry Pi MQTT Broker.
BPlot
BPlot
- BYTE X
- BYTE Y
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
Goto_XY
Goto_XY
- BYTE X
- BYTE Y
Plot
Plot
- BYTE X
- BYTE Y
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Line
Line 0-3
- BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE PixelColour
0=White, 1=Black
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE PixelColour
0=White, 1=Black
Write_Command
Write_Command
- BYTE Command
Write_Data
Write_Data
- BYTE data
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data Pin
Clock Pin
A0
CS
Chip select pin
Reset
Fonts
Font Count
Font 0
Font
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
Simulation Mode
Display Type
LCDVersion
Please click here to download the component source project: FC_Comp_Source_glcd_ST7567_SPI_Free_FormulaAllCode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_glcd_ST7567_SPI_Free_FormulaAllCode.fcfx
