Component: Air Quality (BME688) (Environmental)
| Author | MatrixTSL |
| Category | Environmental |
Air Quality (BME688) component
An air quality sensor connected using a standard I2C bus. Capable of detecting indoor and outdoor air quality including CO2 H2 VOCs and VSCs.
Please click here to download the component source project: FC_Comp_Source_BME688_AirQualitySensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_BME688_AirQualitySensor.fcfx
| Initialises the I2C bus and sets up the device ready for operation. Returns 1 if the device has been found and is communicating. | |
PerformGasResistanceCycle
ReadGasResistance
| ReadGasResistance | |
| Reads the resistance of the gas in ohms from the last heating cycle. | |
ReadHumidity
| ReadHumidity | |
| Collects the humidity and returns as a floating point value in percent. | |
| Index | |
| Forced Mode = 0 / Parallel Mode = 0-2 | |
ReadPressure
| ReadPressure | |
| Collects the pressure and returns as a floating point value in pascal. | |
| Index | |
ReadRegister
| ReadRegister | |
| A simple example showing a generic way to read a register using I2C. | |
| Address | |
ReadTemperature
| ReadTemperature | |
| Collects the temperature and returns as a floating point value in degrees C. | |
| Index | |
SetMode
| SetMode | |
| Sets the mode of the sensor to low power sleep, forced or parallel | |
| Mode | |
| 0=Sleep, 1=Forced, 2=Parallel | |
WriteRegister
| WriteRegister | |
| A simple example showing a generic way to write a register using I2C. | |
| Address | |
| Data | |
