Component: Pedestrian Crossing (Scenarios)
| Version | 7.7 |
| Category | Scenarios |
Pedestrian Crossing component
A set of pedestrian crossing lights complete with manual light control, a simple state machine and an automatic mode to allow the lights to take care of themselves.
Version information
Library Version, Component Version, Date, Author, Info 3, 3.0, 18-09-24, MW, Changed appearance by adding a separate button with a wait indicator 4, 4.0, 25-09-24, MW, Changed when WAIT indictor is switched off 7, 7.0, 28-02-25, MW, Fixed bug which shows both red and green on solid 7, 7.0, 28-02-25, MW, Changed green flash rate so it remains constant during the flash time duration 7, 7.0, 28-02-25, MW, Fixed state 3 as green was not flashing 7, 7.0, 28-02-25, MW, Fixed so Wait is not lit on button press when not required 7, 7.0, 28-02-25, MW, Added tool tip text to SetLightState
AutomaticMode
| AutomaticMode | |
| Enables or Disables automatic mode where the lights will automatically cycle between modes. | |
| Mode | |
| 0 = Auto Mode Disabled, 1 = Auto Mode Enabled | |
GetLightState
| GetLightState | |
| Reads the state of one of the light sets. Returns the state as a number. 0=Red, 1=Red+Wait, 2=Green, 3=FlashingGreen, 4=Unknown State | |
GetStopGo
| GetStopGo | |
| Reads one of the light sets to determine if it is safe to go through the lights. Returns 1 for a Green light, otherwise returns 0. | |
ReadSwitch
| ReadSwitch | |
| Check to see if switch is currently pressed. Return: 0 = Not Pressed, 1 = Pressed | |
SetLightState
SetLights
| SetLights | |
| Direct control over all 3 of the lights. | |
| Red | |
| 0 = Off, 1 = On | |
| Green | |
| 0 = Off, 1 = On | |
| Wait | |
| 0 = Off, 1 = On | |
Please click here to download the component source project: FC_Comp_Source_PedestrianCrossing_GDI.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PedestrianCrossing_GDI.fcfx
