Component: Orientation ( Data)
Revision as of 10:52, 29 April 2026 by SteveT (talk | contribs) (tilt sensor canvas example)
Author MatrixTSL
Category Data
Orientation component
Component that provides orientation data for the mobile device using its internal magnetometer
Version information
1, 1.0, 24-04-26, ST, Created
Many mobile devices contain an internal accelerometer and magnetometer which together can report the orientation of the device.
This component allows access to this orientation data (if it is available on the device), returning with 3 angles showing the rotation of the device in the 3 axes (x, y and z).
Graphing the device orientation
This example shows the orientation of the device in the 3 axes on a chart.
FC6 Icon.png DeviceOrientation.fcweb
The web app created by this example can be viewed here: DeviceOrientation Example
Using the Orientation component with a callback
The is a similar example to above, but this one uses a callback function to retrieve the orientation of the device whenever there is new data available.
FC6 Icon.png DeviceOrientationWithCallback.fcweb
The web app created by this example can be viewed here: DeviceOrientationWithCallback Example
Drawing with the tilt sensor
An example using the tilt sensor to draw onto a canvas.
FC6 Icon.png TiltPlotter.fcweb
The web app created by this example can be viewed here: TiltPlotter Example
GetAlpha
Fc9-comp-macro.png GetAlpha
Returns rotation around the z-axis, i.e. twisted anticlockwise around the centre of the screen (in degrees between 0 and 360)
GetBeta
Fc9-comp-macro.png GetBeta
Returns rotation around the x-axis, i.e. tilted forwards/backwards (in degrees between -180 and 180)
GetGamma
Fc9-comp-macro.png GetGamma
Returns rotation around the y-axis, i.e. tilted left/right (in degrees between -90 and 90)
Fc9-comp-macro.png Initialise
Begins monitoring of the device's orientation information. Returns true if the device can provide orientation information.
IsAbsolute
Fc9-comp-macro.png IsAbsolute
Returns true if the device is providing absolute orientation information. Absolute data will be in reference to the Earth's coordinate frame.
Fc9-type-7-icon.png Use Callback
Set true to use a callback that retrieves regular updates of the device orientation
Please click here to download the component source project: FC_Comp_Source_WEBEXP_Orientation.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_WEBEXP_Orientation.fcsx
