API Sound.Create
Revision as of 13:14, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Create
Creates a sound object that data can be played through
- ULONG SampleRate
The number of samples per second
- BYTE SampleBits
The number of bits per sample - either 8 or 16
- BOOL Stereo
True to treat each pair of samples as a stereo sample
- HANDLE Return
Sounds can only be played directly through the Sound.Play call or through a handle to a sound channel. Sounds played through a handle can be queued and played in sequence, allowing multiple sounds to be played seamlessly.
Sounds can be queued on an event, Sound.Complete, which is a notification that any sound played through this mechanism has finished.
The parameters used here will define the basics of the sound and are used to define the underlying system. Any sounds played have their values adjusted by Flowcode to conform to these values - a sound played which has a native sample rate and details matching the parameters of this call will in general be more efficient and clearer than a sound where the sample rate has to be adjusted to fit.
  • Add to a calculation icon:
    result = ::Sound.Create(samplerate, samplebits, false)
