Component: CNC Machine (Scenarios)
Author Matrix
Category Scenarios
CNC Machine component
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
Please click here to download the component source project: FC_Comp_Source_CNCComponent_v002.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CNCComponent_v002.fcfx
Drill_Speed
Drill_Speed
Will cause the drill to rotate according to the speed. If no speed is set it will stay static.
- FLOAT DrillSpeed
Speed of the Drill. 0=Stopped
HomeMachine
HomeMachine
Moves the machine an axis at a time until the end stop is hit. Finishes by resetting the coordinates to 0,0,0.
Enables the three motors within the component allowing for movement when any of the Axis macros are called.
MoveToXYZ
MoveToXYZ
Moves the tool on the machine to the absolute X Y Z position specified at the speed specified by performing 3D linear interolation.
- FLOAT X
- FLOAT Y
- FLOAT Z
ResetCoordinates
ResetCoordinates
Resets the coordinates to the home position 0,0,0.
XAxisMovement
XAxisMovement
Moves the components X axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE Direction
Assign a value of 1 or 0. 1 will move the component forward. 0 will move it up.
YAxisMovement
YAxisMovement
Moves the components Y axis by 0.01mm. Direction determines direction 1= Forward, 0 = Backward If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE Direction
Assign a value of 1 or 0. 1 will move the component right. 0 will move it left.
ZAxisMovement
ZAxisMovement
Moves the components Z axis by 0.01mm. Direction determines direction 1= Down 0 = Up If collision is detected then movement will stop and the return value will be 1. Otherwise the return value will be 0.
- BYTE Direction
Assign a value of 1 or 0. 1 will move the component down. 0 will move it up.
