Component: IoT Made Easy (Comms: IoT/Cloud)
Category Comms: IoT/Cloud
IoT Made Easy component
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
Please click here to download the component source project: FC_Comp_Source_IoTMadeEasy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_IoTMadeEasy.fcfx
Connect
Connect
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
Disconnect
Disconnect
Disconnects from the MQTT server and the network
ErrorAsString
ErrorAsString
- BYTE Error
- STRING Return
GetPayloadFloat
GetPayloadFloat
Get the Payload of the last received (Read) packet as a floating point value
- FLOAT Return
GetPayloadInteger
GetPayloadInteger
Get the Payload of the last received (Read) packet as a signed long value
- LONG Return
GetPayloadString
GetPayloadString
Get the Payload of the last received (Read) packet as a string value
- STRING Payload
- BYTE Size
GetTopicID
GetTopicID
Compares the topic ID of the last received message with enabled IDs. Returns the topic ID received.
Starts up the MQTT component - call this after initialising the NetworkComms component.
LastError
LastError
Returns the last error
Ping
Ping
Ping packet is sent to the server and checks for a reply. If nothing is sent or received within the keep alive period then a ping is required to keep the connection to the server active. Returns non-zero value if successful
PublishFloat
PublishFloat
Publishes data to the selected topic ID using a floating point value. Returns none zero if successful
- BYTE TopicID
The topic ID to publish data to
- FLOAT Data
Data to publish
PublishInteger
PublishInteger
Publishes data to the selected topic ID using a signed long integer value. Returns none zero if successful
- BYTE TopicID
- LONG Data
Data to publish
PublishString
PublishString
Publishes data to the selected topic ID using a data string. Returns none zero if successful
- BYTE TopicID
- STRING Data
Data string to publish
Read
Read
Read incoming data. Returns non-zero if packet received. Use GetTopicID and GetPayloadXXX to read the contents.
MQTT Properties
LinkTo
Host
Address of MQTT Broker Can be an IP Address or URL (URL only supported by some hardware platforms)
Port
Port used by MQTT Broker Default 1883 for unencrypted access and 8883 for encrypted access.
Client identifier
Client identifier (Maximum length 20 characters) Must be unique to the broker.
Network Timeout
Maximum time in mS to wait for network responses
Read Timeout
Time to wait in ms when waiting for incoming messages
Keep Alive
The Keep Alive is the maximum time interval that is permitted to elapse between the point at which the Client finishes transmitting one Control Packet and the point it starts sending the next, measured in seconds.
Authentication
Selects if the broker is open or if the broker requires a username and password.
Topics
Number of topics
Sets the number of data topics that can be sent or received
Topic ID: 0
Topic String
Topic Type
Topic ID: 1
Topic String
Topic Type
