Component: CRC (Calculation)
Category Calculation
CRC component
Proforms CRC error checking using sum or division methods.
Version information
1, 1.0, 30-09-24, MW, Component created
CRC16
CRC16
Enter databytes and data count. The checksum will be retuened as a byte
- BYTE Data
- BYTE DataLength
Actual Data length is only required if using Final XOR Value greater than 0. If not then Data length can be 0
CRC16_Array
CRC16_Array
Enter databytes and data count. The checksum will be retuened as an unsigned integer
- BYTE Data
- BYTE DataLength
Max data lenght (2 - 20)
CRC8
CRC8
- BYTE Data
- BYTE DataLength
CRC8_Array
CRC8_Array
- BYTE Data
- BYTE DataLength
Max data length (2 - 20)
ClearChecksumValue
ClearChecksumValue
compareChecksum
compareChecksum
Compare generated checksum uisng CRC8 or CRC16 macros. 0 = match, 1 = don't match
- UINT Checksum
- BOOL Return
CRC Type
CRC Size
Poly
Initial Value
Final XOR Value
Please click here to download the component source project: FC_Comp_Source_CRC.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CRC.fcfx
