Component: Advanced String Functions (Utility)
Revision as of 14:16, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;" align="center"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Utility
Advanced String Functions component
A component designed to add more advanced functions to the existing built-in string library.
Please click here to download the component source project: FC_Comp_Source_AdvancedStringFunctions.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_AdvancedStringFunctions.fcfx
Explode
The explode functions use a delimiter to split a string up into an array.
For example "1,2,3,4" using the delimiter ',' would create {1,2,3,4}.
Implode
The implode functions do the reverse and create a string from an array.
for example {1,2,3,4} using the delimiter ',' would create "1,2,3,4".
All of the string functions assume that your string variable is large enough to store the data being passed into it. Overflowing the bounds of the string could lead to RAM corruption which could effect the operation of your program.
Contains
Contains
Scans a string to see if it contains a specific substring. Returns 1 if found, otherwise returns 0.
- STRING StrData
Data string to scan
- STRING StrMatch
String to look for in the data
- BOOL Return
ExplodeToByteArray
ExplodeToByteArray
Takes an ASCII string and using a delimiter converts it into an array of bytes. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
- STRING StringInput
Data string e.g. "1,2,3,4"
- BYTE Delimiter
Delimiting character byte for example ','
- BYTE DataArray
Data array to hold the numberic values found
- UINT MaxCount
Maximum number of values to return
ExplodeToFloatArray
ExplodeToFloatArray
Takes an ASCII string and using a delimiter converts it into an array of floats Returns the number of values discovered and placed into the DataArray, e.g. "1.1,2.2,3.3,4.4" would become {1.1,2.2,3.3,4.4}
- BYTE Delimiter
- FLOAT DataArray
- UINT MaxCount
ExplodeToINTArray
ExplodeToINTArray
Takes an ASCII string and using a delimiter converts it into an array of integers. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {1,2,3,4}
- BYTE Delimiter
- UINT DataArray
- UINT MaxCount
ExplodeToStringArray
Takes an ASCII string and using a delimiter converts it into an array of strings. Returns the number of values discovered and placed into the DataArray, e.g. "1,2,3,4" would become {"1","2","3","4"}
- BYTE Delimiter
- STRING DataArray
- UINT MaxCount
FormattedStringFloat
Converts a floating point value to a string of a fixed size. The value 5 with a length of 3 and a character of '0' would generate "003"
- FLOAT Value
value to format
- BYTE MinLength
The minimum length you want the string to be
- BYTE PaddChar
Added character to padd the string with e.g. ' ' or '0'
- BYTE Precision
Number of decimal points to add
- STRING Return
FormattedStringINT
FormattedStringINT
Converts a signed int to a string of a fixed size. The value 5 with a length of 3 and a character of '0' would generate "003"
- INT Value
value to format
- BYTE MinLength
- BYTE PaddChar
- STRING Return
ImplodeFromByteArray
Creates an ASCII string from an array of byte values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
- BYTE DataArray
- UINT Count
Number of values held in the array
- BYTE Delimiter
Delimiter to add between values
- STRING Return
ImplodeFromFloatArray
Creates an ASCII string from an array of float values. Places a delimiter in between each value. e.g. {1.1,2.2,3.3,4.4} would become "1.1,2.2,3.3,4.4"
- FLOAT DataArray
- UINT Count
- BYTE Delimiter
- BYTE Precision
Number of decimal points to add to each float value
- STRING Return
ImplodeFromINTArray
ImplodeFromINTArray
Creates an ASCII string from an array of integer values. Places a delimiter in between each value. e.g. {1,2,3,4} would become "1,2,3,4"
- UINT DataArray
- UINT Count
- BYTE Delimiter
- STRING Return
ImplodeFromStringArray
Creates an ASCII string from an array of string values. Places a delimiter in between each value. e.g. {"1","2","3","4"} would become "1,2,3,4"
- STRING DataArray
- UINT Count
- BYTE Delimiter
- STRING Return
InsertInto
InsertInto
Inserts a string into another string at the specified index position.
- STRING DataString
Data string to ammend
- STRING Insert
Data to insert
- UINT InsertionIndex
Index location in the string to insert the data
MemCopy
MemCopy
Allows an array of bytes to be copied into another array of bytes at the chosen start address.
- BYTE SourceData
Source data to copy from
- UINT SourceStartAddress
Address in the source to start copying data
- BYTE DestinationData
Data to copy the values into
- UINT DestinationStartAddress
Address in the destination to start inserting data
- UINT NumBytes
Number of values to copy from the source to the destination
PositionOf
PositionOf
Scans a string to see if it contains a specific substring. Returns the location in the string if found, otherwise returns -1.
- STRING StrData
Data string to scan
- STRING StrMatch
- UINT SearchFrom
Starting index for the search, default 0.
- INT Return
RemoveFrom
RemoveFrom
Allows a set number of characters to be removed from a starting location in a string.
- STRING DataString
- UINT CharsToRemove
Number of characters to remove from the string
- UINT StartingIndex
Index location in the string to delete the data
SearchAndReplace
SearchAndReplace
Attempts to find a specific string inside the data string and if found replaces with the provided replacement string. Returns the number of times the search pattern was found.
- STRING StrData
Data string to scan
- STRING StrSearch
- STRING StrReplace
String to insert into the data
