Component: Barometer (BME280) (Environmental)
Version 1.3
Category Environmental
Barometer (BME280) component
A small PCB surface mount barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 °C. Works with I2C interface only.
BME280 Barometer plus Altitude v1.0 This example reads and displays the pressure, temperature & humidity. If the pressure is increasing then Rise will be displayed.
Circuit Diagram
Forced_Read
Forced_Read
I2C_Read_Register
I2C_Read_Register
Reads a byte value from a register on the device
- BYTE Address
I2C_Write_Register
I2C_Write_Register
Writes a byte value to a register on the device
- BYTE Address
- BYTE Value
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected.
ReadHumidityFloat
ReadHumidityFloat
Reads the humidity as a floating point value in percentage 0-100%. Calls the ReadHumidityRaw function and then converts to a meaningful value.
- FLOAT Return
ReadPressureFloat
ReadPressureFloat
Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value.
- FLOAT Return
ReadTemperatureFloat
- FLOAT Return
Reset
Reset
Resets the device
Uninit
Uninit
Uninitialse and release I2C resources
Slave Address
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Sensor Options
Compensation
Compensation formulas in double precision floating point or 32 bit fixed point
Humidity Oversampling
Pressure Oversampling
Temperature Oversampling
Mode
Standby Normal Mode (ms)
Filter Coefficient
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_Pressure_Sensor_BME280.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Pressure_Sensor_BME280.fcfx
