Component: MIAC Advanced (MIAC: Addon Modules)
Author
Category MIAC: Addon Modules
MIAC Advanced component
Advanced Addon for MIAC System
FREE
UART_ReceiveChar
- BYTE Timeout
PWM_Enable
Enable the PWM on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
MI2C_Send_Byte_Transaction
[[File:]] - Device_ID
[[File:]] - AddrH
[[File:]] - AddrL
[[File:]] - Data
RTC_Read_Time
[[File:]] - HMS
[[File:]] - Return
RTC_Set_Date
[[File:]] - Day
[[File:]] - Month
[[File:]] - Year
SPI_Uninit
MI2C_Stop
DAC_WriteChannels
Wrtie values to both DAC Channels
- INT ChannelA
- INT ChannelB
UART_SendString
- STRING Text
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
MIAC_Module_Init
- UINT CAN_ID
MIAC_Module_GetData
- BYTE Index
SPI_Init
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
RTC_Reg_Write
[[File:]] - Reg
[[File:]] - Value
MIAC_Module_WR
- UINT CAN_ID
- UINT CMD_ID
[[File:]] - Count
[[File:]] - Start
[[File:]] - More
MI2C_Restart
LED_Control
Sets the indicator LED On (State=1) or Off (State=0)
- BYTE State
RTC_Read_Date
[[File:]] - DMY
[[File:]] - Return
SPI_Get_Char
[[File:]] - Return
UART_Initialize
SPI_Send_Char
[[File:]] - Char
MI2C_Transmit_Byte
[[File:]] - Data
[[File:]] - Return
Sensor_Read
[[File:]] - Sensor
[[File:]] - HiRes
- INT Return
MIAC_Module_PushData
- BYTE Data
MI2C_Receive_Byte
[[File:]] - Last
MI2C_Init
PWM_Disable
Disable the PWM on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
RTC_Reg_Read
[[File:]] - Reg
[[File:]] - Return
MI2C_Receive_Byte_Transaction
[[File:]] - AddrH
[[File:]] - AddrL
[[File:]] - Return
DigitalOutput
Set a Terminal Output to High (Value=1) or Low (Value=0)
- BYTE Terminal
- BYTE Value
MIAC_Module_GetAck
- UINT CAN_ID
- UINT CMD_ID
- UINT TimeOut
DAC_Write
[[File:]] - Channel
- INT Value
AnalogInput
Read the ADC value of a Terminal Returns 12 bit ADC reading
- BYTE Terminal
Terminal number to be read
Initialize
Forces a software reset on the module
RTC_Get_Data
RTC_Set_Time
[[File:]] - Hour
[[File:]] - Min
[[File:]] - Sec
UART_ReceiveString
- BYTE Timeout
- BYTE NumBytes
- STRING Return
PWM_SetDuty
Sets the PWM Duty cycle on Channel 1 or 2
- BYTE Channel
PWM Channel 1 or 2
- BYTE Duty
Duty cycle (8 bit value)
MI2C_Start
DigitalInput
Read the value of a terminal
- BYTE Terminal
UART_SendChar
- UINT Character
Module Type
Module Address
Period Overflow
Prescaler
Frequency (KHz)
Period (uS)
Data Bits
Return Type
Echo
Flow Control
Rate
Prescale option selector
Clock Polarity
Clock Phase
Sample Point
Data bit read sample point
Baud Select
Slew Rate Control
Slew Rate Control Enabled or Disabled
SMBus Inputs
When Enabled input logic thresholds are compliant with SMBus specification
Simulations
