Component: MULTIUART (SPI2UART) (Comms: Interface)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 2.0
Category Comms: Interface
MULTIUART component
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
Please click here to download the component source project: FC_Comp_Source_MULTIUART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MULTIUART.fcfx
Simple test program
CheckRx
CheckRx
Returns the number of received bytes held in queue for the selected channel.
- BYTE UART
UART Index Range: 0-3
CheckTx
CheckTx
Returns the number of bytes held in the transmit queue for the selected channel.
- BYTE UART
Activates the SPI peripheral and claims control over the I/O pins.
ReceiveByte
ReceiveByte
Returns the first received byte held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
- BYTE UART
ReceiveString
ReceiveString
Returns a string of received bytes held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
- BYTE UART
- BYTE NumBytes
- STRING Return
SetBaud
SetBaud
Adds a byte to the transmit queue for the selected channel.
- BYTE UART
- BYTE Baud
TransmitByte
TransmitByte
- BYTE UART
- BYTE Data
TransmitString
TransmitString
- BYTE UART
- STRING Data
Bus Settings
SPI Channel selector
Prescale
Prescale option selector
MOSI
MOSI Remap Pin
MISO
MISO Remap Pin
CLK
CLK Remap Pin
CS / SS
Label used to identify the component on the panel.
API
