Component: Input Digital (DSP Inputs)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.2
Category DSP Inputs
Input Digital component
Allows the values from a buffer to be assigned. Either a value at a time or from an array. The input signal would usually take the form of an ADC reading or raw data values.
Please click here to download the component source project: FC_Comp_Source_DSP_Input.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Input.fcfx
Here is a basic example demonstrating how to pass a value into the DSP chain.
Delay
The input value in the example uses an ADC reading but this can be taken from anything such as a reading from a CSV file on a SD card or a value passed by a sensor on a I2C bus etc.
AddByte
AddByte
Adds a single byte value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- BYTE Data
AddByteArray
AddByteArray
Adds an array of byte values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- BYTE Data
- UINT Count
AddFloat
AddFloat
Adds a single float value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- FLOAT Data
AddFloatArray
AddFloatArray
Adds an array of float values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- FLOAT Data
- UINT Count
AddInt
AddInt
Adds a single integer value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- UINT Data
AddIntArray
AddIntArray
Adds an array of integer values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- UINT Data
- UINT Count
AddLong
AddLong
Adds a single long value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- ULONG Data
AddLongArray
AddLongArray
Adds an array of long values to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1.
- ULONG Data
- UINT Count
Buffer Size
Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
