Component: JSON Encoder (Comms: IoT/Cloud)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Comms: IoT/Cloud
JSON Encoder component
Allows dynamic key and value pairs to be created and assembled into a formatted JSON string.
Please click here to download the component source project: FC_Comp_Source_JSONEncoder.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_JSONEncoder.fcfx
Simple Data
Example program showing how to use a JSON encoder component to create a simple JSON encoded data string.
JSON Encoder Example
Simple Encode and Decode
Example program showing how to take data and encode it into a JSON string to be sent out over comms.
The example also hows how to decode a received JSON string and pull out values.
JSON_Demo
AssignDataAsFloat
AssignDataAsFloat
Assigns a data value as a floating point value
- UINT Element
Index of the element to assign the data to
- FLOAT Data
- BYTE NumDP
Number of decimal points
AssignDataAsNumber
AssignDataAsNumber
Assigns a data value as a integer value
- UINT Element
- LONG Data
AssignDataAsString
AssignDataAsString
Assigns a data value as a string
- UINT Element
- STRING Data
AssignName
AssignName
Assigns a name value as a string. Call this macro first before assigning data to the element.
- UINT Element
- STRING Name
ClearAll
ClearAll
Clears all the names and data values out of the buffer
GenerateJSON
GenerateJSON
Generates a JSON data string with the current specified values.
- STRING Return
Data Bytes
Number of bytes used to store the entire data for the JSON message. Includes names and data values so make sure this is large enough to store everything you want to be able to put into a single JSON data string.
