Component: ADC Template 2D (Analog Input)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.3
Category Analog Input
ADC Template 2D component
Base ADC component with no graphical interface. Contains all of the embedded side component calls to provide an ADC interface suitable for wrapping with a new ADC style component.
GetAverageByte
GetAverageByte
Function call to read the ADC as a byte average sample over time
- BYTE NumSamples
- BYTE DelayUs
Number of micro seconds in between taking each sample
GetAverageInt
GetAverageInt
Function call to read the ADC as a full width average sample over time
- BYTE NumSamples
- BYTE DelayUs
GetByte
GetByte
Blocking call to read the ADC as a byte
GetInt
GetInt
Blocking call to read the ADC at full bit depth
GetSampleBits
GetSampleBits
Gets the number of bits per sample
GetSpeedFilter
GetSpeedFilter
Gets the Conversion speed filter string Use in Component.Property.SetFilter()
- STRING Return
GetString
GetString
Reads the ADC as a direct voltage and returns as a string
- STRING Return
GetVoltage
GetVoltage
- FLOAT Return
RawAverageByte
RawAverageByte
Background call to read the ADC as a byte average sample over time Call Enable() before this
- BYTE NumSamples
- BYTE DelayUs
RawAverageInt
RawAverageInt
Background call to read the ADC as a full width average sample over time Call Enable() before this
- BYTE NumSamples
- BYTE DelayUs
- INT Return
RawDisable
RawDisable
Disables the previously enabled ADC channel and converts back to digital mode.
RawEnable
RawEnable
Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only.
RawSampleByte
RawSampleByte
Background call to read the ADC as a byte Call Enable() before this
RawSampleInt
RawSampleInt
Background call to read the ADC at full bit depth Call Enable() first
SetChannel
SetChannel
Sets the channel ID for the component
- INT ChannelId
Chaannel starting at 0, -1 is unconnected
SetProperties
SetProperties
Set the VRef options and voltage, ConvSpeed and AcqTime for the ADC component.
- INT VRef10Ms
Voltage Reference x10 mV - Default 500 = 5V
- BOOL VRefOpt
External VRef 0=Disabled, 1=Enabled
- INT ConvSpdOpt
Conversion Speed Setting - Refer to numbered list
- INT Aquisitions
Aquisition time in micro seconds to precharge before sampling
Settings
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Please click here to download the component source project: FC_Comp_Source_adc_Base_2dgdi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_adc_Base_2dgdi.fcfx
