Component: GLCD (EB043 v1) (E-blocks 1)
Revision as of 14:20, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 1.3
Category E-blocks 1
GLCD (EB043 v1) component
Graphical display component designed to work with the legacy version 1 EB043 E-blocks.
Version information
EB043 v1 gLCD Example File EB043 Example Example should show the following on the display on the panel and on the hardware.
BPlot
BPlot
- UINT X1
- UINT Y1
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT X
Center X coordinate
- UINT Y
Center Y coordinate
- UINT Radius
Radius, distance of edge from the centre coordinates
- FLOAT StartAngle
Angle to start drawing, in degrees
- FLOAT EndAngle
Angle to end drawing, in degrees
- UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawBezier
DrawBezier
Draws a quadratic Bezier curve with the current foreground colour from pixel location X0, Y0 to pixel location X2, Y2 using control point CX, CY.
- UINT X0
Start X coordinate
- UINT Y0
Start Y coordinate
- UINT CX
Control point X coordinate
- UINT CY
Control point Y coordinate
- UINT X2
End X coordinate
- UINT Y2
End Y coordinate
- UINT Resolution
Number of segments to approximate the curve, 0 chooses an automatic value based on curve size.
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
Chooses the transparency of the box - 0 = Box contains background colour, 1 = Box contains previous pixel data
- BYTE Solid
Draws a rectangle with rounded corners
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- UINT Radius
- BYTE Transparent
- BYTE Solid
FastPlot
FastPlot
Plot
Plot
- UINT X1
- UINT Y1
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
SetDisplayOrientation
- BYTE Orientation
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data
Data pin connection
Clock
Clock pin connection
Chip Select
Chip select pin connection
Reset
Reset pin connection
Fonts
Font Count
Font 0
Font
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_EB043-00-1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_EB043-00-1.fcfx
