Component: ST3215 Servo Motor (Mechatronics)
| Version | 2.0 |
| Category | Mechatronics |
ST3215 Servo Motor component
Control ST3215 servo motors via serial UART communication using the STS protocol.
ChangeBaudrate
ChangeID
DefineMiddle
| DefineMiddle | |
| Define the 2048 position by setting torque to 128. | |
| ServoID | |
| Servo ID | |
IsMoving
| IsMoving | |
| Check if the servo is currently moving. Returns True if moving, False otherwise. | |
| ServoID | |
| Servo ID | |
ListServos
LockEEPROM
| LockEEPROM | |
| Lock EEPROM to prevent writes from being saved after power loss. IMPORTANT: Use the NEW servo ID after ChangeID. | |
| ServoID | |
| Servo ID (use NEW ID after ChangeID) | |
PingServo
| PingServo | |
| Check if a servo is responding. Returns True if successful, False otherwise. | |
| ServoID | |
| Servo ID to ping (0-253) | |
ReadAcceleration
| ReadAcceleration | |
| Read current acceleration value in steps per second squared. | |
| ServoID | |
| Servo ID | |
ReadAngle
| ReadAngle | |
| Read current position of servo. Returns position in steps (0-4095). | |
| ServoID | |
| Servo ID | |
ReadCorrection
| ReadCorrection | |
| Read position correction value in steps. | |
| ServoID | |
| Servo ID | |
ReadCurrent
| ReadCurrent | |
| Read current in milliamps (6.5mA resolution). Returns current / 6.5. | |
| ServoID | |
| Servo ID | |
ReadID
| ReadID | |
| Read the servo ID from EEPROM. Returns the stored ID value. | |
| ServoID | |
| Servo ID to query | |
ReadLoad
| ReadLoad | |
| Read motor load in percentage. Returns load percentage. | |
| ServoID | |
| Servo ID | |
ReadMode
| ReadMode | |
| Read current operational mode. Returns: 0=position, 1=speed, 2=PWM, 3=step | |
| ServoID | |
| Servo ID | |
ReadPosition
| ReadPosition | |
| ServoID | |
| Servo ID | |
ReadSpeed
| ReadSpeed | |
| Read current speed of servo. Returns speed in steps per second. | |
| ServoID | |
| Servo ID | |
ReadStatus
| ReadStatus | |
| Read servo status flags. Returns status byte with bits: Voltage, Sensor, Temperature, Current, Angle, Overload | |
| ServoID | |
| Servo ID | |
ReadTemperature
| ReadTemperature | |
| Read temperature in degrees Celsius. | |
| ServoID | |
| Servo ID | |
ReadTorqueLimit
| ReadTorqueLimit | |
| Read torque limit value (0-1000). | |
| ServoID | |
| Servo ID | |
ReadVoltage
| ReadVoltage | |
| Read voltage in volts (0.1V resolution). Returns voltage * 10. | |
| ServoID | |
| Servo ID | |
Rotate
SetAcceleration
| SetAcceleration | |
| Set servo acceleration in steps per second squared. | |
| ServoID | |
| Servo ID | |
| Acceleration | |
| Acceleration value (0-254) | |
SetAngle
| SetAngle | |
| Move servo to a target angle. Angle range: -180 to 180 degrees. | |
| ServoID | |
| Servo ID | |
| Angle | |
SetCorrection
| SetCorrection | |
| Set position correction value in steps. Adds correction to position. | |
| ServoID | |
| Servo ID | |
| Correction | |
| Correction value in steps | |
SetMode
| SetMode | |
| Set operational mode. Mode: 0=position, 1=speed, 2=PWM, 3=step | |
| ServoID | |
| Servo ID | |
| Mode | |
SetPosition
| SetPosition | |
| Move servo to a target position. Position range: -30719 to 30719 steps. | |
| ServoID | |
| Servo ID | |
| Position | |
| Target position in steps (0 to 4095) | |
SetSpeed
| SetSpeed | |
| Set servo speed in steps per second. | |
| ServoID | |
| Servo ID | |
| Speed | |
| Speed in steps per second (0-3400) | |
SetTorqueLimit
| SetTorqueLimit | |
| Set torque limit value (0-1000). Controls maximum torque output. | |
| ServoID | |
| Servo ID | |
| TorqueLimit | |
| Torque limit value (0-1000) | |
StartServo
| StartServo | |
| Enable torque (start servo). | |
| ServoID | |
| Servo ID | |
StopServo
| StopServo | |
| Disable torque (stop servo). | |
| ServoID | |
| Servo ID | |
UnlockEEPROM
| UnlockEEPROM | |
| Unlock EEPROM to allow writes to be saved after power loss. | |
| ServoID | |
| Servo ID | |
Please click here to download the component source project: FC_Comp_Source_ST3215.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ST3215.fcfx
