Component: Standard Deviation (Calculation)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Author MatrixTSL
Category Calculation
Standard Deviation component
A set of functions used to calculate the mean and standard deviation on a set of data samples.
Please click here to download the component source project: FC_Comp_Source_StandardDeviation.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_StandardDeviation.fcfx
AddSample
AddSample
Adds a sample to the first in first out sample buffer.
- FLOAT Sample
Value to add into the FIFO buffer
GetDeviation
GetDeviation
Gets the standard deviation of the values in the first in first out buffer
- FLOAT Return
GetMean
GetMean
Gets the mean of the values in the first in first out buffer
- FLOAT Return
InitialiseFIFO
InitialiseFIFO
initialises the first in first out buffer values to 0
SetSampleCount
SetSampleCount
Sets the number of samples when using the variable sample count type.
- UINT SampleCount
Sample Count Type
Controls if the number of samples to determine the mean and deviation are fixed or variable, Fixed has some additional optimisations when adding samples but variable allows flexibility. The sample count for variable samples defaults to the max count and can be set using the SetSampleCount macro.
Number of Samples
Fixed number of samples used to calculate the mean and deviation. Samples are first in first out so the newest sample will replace the oldest.
Initial Sample Value
Sets the initial value of each sample when initialising the FIFO.
