Component: Numeric Label (Indicators)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Indicators
Numeric Label component
Allows a numeric label to be displayed on the user panel. Used for displaying the value of a variable during simulation runtime. Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
Please click here to download the component source project: FC_Comp_Source_NumericLabel.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_NumericLabel.fcfx
DisplayAsInt
DisplayAsInt
Displays an integer value on the label. Capable of displaying positive and negative values.
- LONG Value
Integer value to display
DisplayAsReal
DisplayAsReal
Displays a floating point value on the label with a confiiguarable number of decimal points
- FLOAT Value
Real floating point value to display
- BYTE Precision
Number of decimal point values to show e.g. 2 = 0.00
SetForegroundColour
SetForegroundColour
Allows the user to manually specify the default colour of the foreground text.
- LONG Colour
RGB colour in the hexadecimal form 0xBBGGRR, -1 for Transparent
SetUnits
SetUnits
Allows the user to manually specify the units string that is appended to the end of the label.
- STRING Units
Title
Show Title
Decides if the title is shown on the panel.
Title Text
Specifies the title displayed on the panel.
Title Scale
Specifies the size of the title on the panel, default 1.2
Title Colour
Specifies the colour of the title text
Title Offset
Distance above component center to draw the title
Label Properties
Label Scale
Specifies the scale of the label text, default 1.0
Show Units
Specifies if the unit text is appended to the end of the numeric value
Unit Text
Optionally adds a unit label to the end of the displays string
Colour Ranges
Allows ranges to be specified to automatically format the foreground and background colours based on the numeric value
Defaults
Numeric Colour
The label Text colour
