Component: Thermocouple (MCP960X) (Environmental)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Version 6.0
Category Environmental
Thermocouple (MCP960X) component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Version information
6.0, 6.0, 02-07-24, MW, As requested By Stefan. Exposed ReadRegister/s, WriteRegister and renamed with underscore. Added Write_N_Registers.
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
MCP960X Demo
Sim Demo
Configures the I2C bus ready for communications.
ReadReference_Float
ReadReference_Float
Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures.
- FLOAT Return
ReadReference_Int
ReadReference_Int
Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures.
- INT Return
ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures.
- FLOAT Return
ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures.
- INT Return
Read_N_Registers
Read_N_Registers
Reads a number of sequential bytes starting from the specified register
- BYTE Address
- BYTE Data
- BYTE Count
Read_Register
Read_Register
Reads a byte from a register
- BYTE Address
Sample
Sample
Must be called before any of the Read functions. Reads the memory of the MCP9600/1 IC. Returns 0 for 9600. Checks for errors, MCP9601 only. Returns: 0 = OK, 1 = O/ C Themocouple & 2=S/C Themocouple.
Write_N_Registers
Write_N_Registers
Writes a set of data values to a sequential registers on the accelerometer
- BYTE Start_Reg
- BYTE Num_Regs
- STRING Data
Write_Register
Write_Register
Writes a byte to a register
- BYTE Address
- BYTE Data
Thermocouple Properties
Thermocouple Type
Thermocouple type. Selects which type of thermocouple the IC works with.
Filter Coefficients
Digitial filter selection. The higher the number the better the filter. Results more stable but take longer to update.
Unit
Select Temperature results to be celsius or fahrenheit
I2C Properties
Address
Address ranges 0x60 - 0x67 (96 - 103)
Channel selection
SDA
SCL
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMCP960X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMCP960X.fcfx
