Component: Simulation 7 Seg (Advanced Shapes)
Revision as of 14:21, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="10%" align="center" style="background-color:#D8C9D8;"" to "width="10%" align="center" class="mtx-class-macrohead"")
Category Advanced Shapes
Simulation 7 Seg component
Simulated single digit seven segment display. LED colour can be changed in properties.
FREE
ClearDigit
This funtion clears all the individual segments including the decimal point segment. In simulation this sets the colours to the default BGColor component variable. It's default value is 0xCCCCCC
ShowDigit
Creates the supplied digit on the 7 segment display. Macro takes the digit to display and a boolean representing whether to display the decimal point segment or not.
- BYTE Digit
Sets the 7seg display with the appropriate digit supplied
- BYTE DecimalPoint
Determines whether decimal point LED is active (True/False)
SegControl
Direct control over the display segments
- BYTE data
LED On Color
Color when an LED is turned on.
LED Off Color
Color when an LED is turned off.
Bezel Color
Color of the plastic package housing the LEDs
Simulations
