Component: JSON Decoder (Comms: IoT/Cloud)
Revision as of 14:22, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Version 1.1
Category Comms: IoT/Cloud
JSON Decoder component
Allows dynamic key and value pairs to be collected from a formatted JSON string.
Version information
4, 1.1, 10-10-24, BR, Allowed for better support of nested array data
4, 1.1, 10-10-24, BR, Removed spaces and new lines etc from the stored data
5, 1.1, 02-15-24, BR, Allowed for better support of nested array data for the FindName function
Simple Decode
Example program showing how to use a JSON decoder component to parse a simple JSON encoded data string. JSON Decoder Example
Simple Encode and Decode
Example program showing how to take data and encode it into a JSON string to be sent out over comms.
The example also hows how to decode a received JSON string and pull out values.
JSON_Demo
FindName
FindName
Searches for a name in the JSON data. Returns the data index position. Returns -1 if the name was not found.
- STRING Name
- UINT SkipCount
Number of matches to skip before returning.
- INT Return
ParseJSON
ParseJSON
Accepts a JSON formatted data string and stores locally in the data buffer ready for parsing. Returns the estimated number of name and data keys present.
- STRING Data
JSON data string to parse
ReadDataAsFloat
ReadDataAsFloat
Reads the data of a specific element as a floating point value
- UINT Element
Index of the element to read
- FLOAT Return
ReadDataAsNumber
ReadDataAsNumber
Reads the data of a specific element as a numeric integer value
- UINT Element
- LONG Return
ReadDataAsString
ReadDataAsString
Reads the data of a specific element as a string value
- UINT Element
- STRING Return
ReadName
ReadName
Reads the name of a specific element
- UINT Element
The Index of the element to read
- STRING Return
Data Bytes
Number of bytes used to store the entire data for the JSON message. Includes names and data values so make sure this is large enough to store everything you want to be able to put into a single JSON data string.
Please click here to download the component source project: FC_Comp_Source_JSONDecoder.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_JSONDecoder.fcfx
