Component: Isolated Input (BL0121) (E-blocks 2)
Revision as of 14:22, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Version 8.8
Category E-blocks 2
Isolated Input component
A set of 2 isolated inputs that can take a high voltage or floating input and convert to a standard digital input via the use of opto isolators. A high is received when the voltage across the terminals is low 0 - 4V. A low is received when the voltage across the terminals is high 6 - 48V.
Version information
8, 8.0, 02-04-25, MW, ESP32 compile fail. Added .Retun to ReadState function
9, 8.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise
ReadAll
ReadAll
Reads all of the inputs at once, returning a byte containing one bit per input. Range 0-3.
ReadState
ReadState
Read the state of the input at the given index. 0 = Voltage Present on input, 1 = No Voltage Present on input
- BYTE Index
The input to read the status of. 0 or 1
- BOOL Return
WaitUntilHigh
WaitUntilHigh
Pause the program until the input at the given index is turned on.
- BYTE Index
Index of the switch to wait for.
WaitUntilLow
WaitUntilLow
Pause the program until the input at the given index is turned off.
- BYTE Index
Input Mode
Choose how your switches are connected. PORT = Single port byte for all switches - pins are allocated in sequence from pin 0 - X Custom = Individual pin by pin connections
Port
Switch 0
Switch 1
Please click here to download the component source project: FC_Comp_Source_EB_IsolatedInput_BL0121.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_IsolatedInput_BL0121.fcfx
