Component: LCD (BL0169) (E-blocks 2)
Category E-blocks 2
LCD component
LCD component to drive the E-blocks 2 BL0169 LCD board. Provides a 4 x 20 character alphanumeric display.
Version information
4, 1.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise
Example showing the basic function of BL0169 E-blocks 2 alphanumeric Display.
BL0169 LCD Demo
Clear
Clear
ClearLine
ClearLine
- BYTE Line
The line to clear, zero being the first (top) line of the display
Cursor
Cursor
- BYTE x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
PrintAscii
PrintAscii
- BYTE character
Holds an ascii value.
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
PrintString
PrintString
- STRING Text
Enter the text or variable to print to the LCD
RAMWrite
RAMWrite
- BYTE Index
Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
RawSend
RawSend
Sends data to the LCD display
- BYTE data
The data byte to send to the LCD
- BOOL type
A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
Character to look for a replace
- BYTE ReplacementCharacter
New character value to use in place of the search character.
Start
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Data 0 (11 / 7)
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Data 1 (12 / 8)
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Data 2 (13 / 9)
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Data 3 (14 / 10)
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Register Select (4)
Register Select Pin - Informs the display if a command or data is about to be sent.
Enable (6)
Enable pin - Used to synchronise data writes to the display
Component Label
User Label Text
Text to display
Component Label Scale
Text Colour
Colour of the font characters drawn on the display
Text Background
Colour surrounding the font characters drawn on the display
Display Background
Colour of the background of the display
Please click here to download the component source project: FC_Comp_Source_EB_LCD_BL0169.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_LCD_BL0169.fcfx
