Component: Level (DSP Outputs)
Revision as of 14:22, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "width="90%" style="background-color:#D8C9D8; color:#4B008D;"" to "width="90%" class="mtx-class-macrohead"")
Version 1.2
Category DSP Outputs
Level component
Allows for detection and collection of peaks, troughs and averages.
Please click here to download the component source project: FC_Comp_Source_DSP_Level.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Level.fcfx
Here is a basic example of the Level component. The example collects the max, min and average readings from the buffer and displays them on the LCD display.
Level
The values in the buffer are defined using the InputADC component.
Min: Minimum (smallest) value read from the buffer.
Max: Maximum (largest) value read from the buffer.
Average: Rolling average calculated from the values inside the buffer.
ReadAverage
ReadAverage
Returns the average from the last "Decay" number of index locations.
- LONG Return
ReadAverageArray
ReadAverageArray
Returns the average from the last "Decay" number of buffers.
ReadPeak
ReadPeak
Returns the highest value from the last "Decay" number of index locations.
- LONG Return
ReadPeakArray
ReadPeakArray
Returns the highest value from the last "Decay" number of buffers.
ReadTrough
ReadTrough
Returns the lowest value from the last "Decay" number of index locations.
- LONG Return
ReadTroughArray
ReadTroughArray
Returns the lowest value from the last "Decay" number of buffers.
ResetRecords
ResetRecords
Allows the peak and trough to be reset back to default values.
- BOOL ResetPeak
- BOOL ResetTrough
Connect To
Decay on Peak/Trough
Yes - The Peak and Trough value will only be maintained for the decay number of buffers. No - The record Peak and Trough values will be maintained until reset.
Decay
Configures how many buffers or values to allow a record to persist
