Component: Combo Board (EB083) (E-blocks 1)
Category E-blocks 1
Combo Board component
A component to drive the EB083 Combo board including LEDs, Switches, LCD, 7-Segs and analogue inputs.
Please click here to download the component source project: FC_Comp_Source_EB086_DEMO.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB086_DEMO.fcfx
The following files provide examples of how to use this component:
Arduino Mega 2560 & Combo Board
This blank project consists of the Matrix EB083 Combo Board connected to an Arduino Mega 2560.
Arduino Uno R3 & Combo Board
This blank project consists of the Matrix EB093 Combo Board connected to an Arduino Uno R3.
Note; Due to a limitation in the Arduino Uno hardware, portA6 & PortA7 are replicated from PortA5 in this template.
Clear
Clear
ClearLine
ClearLine
- BYTE Line
The line to clear, zero being the first (top) line of the display
Command
Command
- BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Cursor
Cursor
- BYTE x
Set the cursor position in the X plane, 0 is the left most cell
- BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
GetPort
GetPort
Reads the state of a single port
- BYTE Bank
0 = Top Bank of Switches, 1 = Bottom Bank of Switches
GetSwitchState
GetSwitchState
Reads the state of a single switch Returns: 0 = Switch not pressed, 1 = Switch pressed
- BYTE Bank
- BYTE Switch
0 = SW0, 7 = SW7
PrintAscii
PrintAscii
- BYTE character
Holds an ascii value.
PrintFloat
PrintFloat
- FLOAT Number
- BYTE DecimalPlaces
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT Number
PrintString
PrintString
- STRING Text
Enter the text or variable to print to the LCD
RAMWrite
RAMWrite
- BYTE Index
Values 0 to 7
- BYTE d0
- BYTE d1
- BYTE d2
- BYTE d3
- BYTE d4
- BYTE d5
- BYTE d6
- BYTE d7
RawSend
RawSend
Sends data to the LCD display
- BYTE data
The data byte to send to the LCD
- BOOL type
A boolean to indicate command type: true to write data, false to write a command
ReadAnalogAsByte
ReadAnalogAsByte
Reads one of the analogue components as an byte value
- BYTE Channel
0 = Light Sensor, 1 = Potentiometer
ReadAnalogAsInt
ReadAnalogAsInt
Reads one of the analogue components as an Integer value
- BYTE Channel
- INT Return
RemapCharacter
RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
- BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
- BYTE SearchCharacter
Character to look for a replace
- BYTE ReplacementCharacter
New character value to use in place of the search character.
ScrollDisplay
ScrollDisplay
- BYTE Position
Holds the number of positions to shift the display
- BYTE Direction
0 = left, 1 = right
SegShowDigit
SegShowDigit
Displays a digit on the 7-seg display
- BYTE Digit
Which of the digits to change (0 - 3)
- BYTE Value
The value to display (0 - 9)
- BYTE DecimalPoint
Decides if the decimal point is lit
SegShowSegments
SegShowSegments
Allows the individual segments of the display to be controlled.
- BYTE Digit
- BYTE Segments
8-bit Binary value to set the segments, bit0 = segA, bit1 = segB...
SetLEDState
SetLEDState
Sets the state of a single LED
- BYTE Bank
0 = Top Bank of LEDs, 1 = Bottom Bank of LEDs
- BYTE LED
0 = LED0, 7 = LED7
- BYTE State
0 = Off, 1 = On
SetPort
SetPort
Sets the state of a single port
- BYTE Bank
- BYTE Value
Start
Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Connection Type
Bank 0 Connections
Bank 0
Bank 1 Connections
Bank 1
Analog Connections
Light Sensor
Light Sensor ADC channel Connected to Bank 0 pin 0 which is usually analog pin AN0.
Potentiometer
Potentiometer ADC channel Connected to Bank 0 pin 1 which is usually analog pin AN1.
Analog Scope Traces
Controls if traces are automatically added to the data recorder window for the analogue signals on the combo board.
