| Author
Matrix TSL
| Version
2.0
| Category
Environmental
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. Default calibration is for the EBM003 module.
9, 2.0, 19-07-24, BR, Added compatibility for external ADC
9, 2.0, 19-07-24, BR, Allowed full bit depth usage of the internal ADC
CalculateTemperature
| Converts the input ADC value and returns the Temperature in tenths of degree C
- UINT
ADCValue
| ADC Reading to be converted
- INT
GetADCValue
GetADCValue
| Returns the Raw ADC value from the Analogue Channel
- UINT
GetIntegerTemperature
| Reads the ADC input and returns the calculated Temperature as Integer degrees C
- INT
GetRealTemperature
GetRealTemperature
| Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
- FLOAT
SetADCValue
SetADCValue
| Used to set the ADC value when an external ADC is being used.
- UINT
AdcValue
| Value of the external ADC. e.g. 0-255 for an 8-bit ADC
SetChannel
SetChannel
| Set the ADC Channel
- INT
ChannelID
SetMinMax
SetMinMax
| Set the minimum and maximum temperature values that can be shown and set on the thermometer readout.
- FLOAT
Min
| Minimum Value
- FLOAT
Max
| Maximum Value
SetTemperature
SetTemperature
| Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
- FLOAT
Temperature
| Zero to one value - representing min-max of the sensor.
ADC Properties
ADC Configuration
ADC Channel
| Analogue Input Channel - Which pin is the analogue input connected to?
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Acquisition cycles
| Number of micro seconds to wait for the ADC input to charge before starting the analogue sample.
Thermistor Properties
Wiring
| Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
Resistor Value
| Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
-25C Thermistor Value
| Value in Ohms of the Thermistor at -25 deg C
0C Thermistor Value
| Value in Ohms of the Thermistor at 0 deg C
| Value in Ohms of the Thermistor at 25 deg C
50C Thermistor Value
| Value in Ohms of the Thermistor at 50 deg C
75C Thermistor Value
| Value in Ohms of the Thermistor at 75 deg C
100C Thermistor Value
| Value in Ohms of the Thermistor at 100 deg C
125C Thermistor Value
| Value in Ohms of the Thermistor at 125 deg C
| A text label to help you identify the component on the panel.
Min. Temp.
| Minimum termperature that can be set or displayed on the thermometer slider.
Max. Temp.
| Maximum termperature that can be set or displayed on the thermometer slider.
Scale divisions
| Number of numbered divisions shown on the thermometer scale.
Please click here to download the component source project: FC_Comp_Source_Thermistor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor.fcfx
