Component: MQTT Client (Comms: IoT/Cloud)
Version 1.1
Category Comms: IoT/Cloud
MQTT Client component
A component providing access to MQTT IoT client. The client can connect to a MQTT server such as ThingSpeak. Allowing IoT type data to be published and read back.
Version information
7, 1.1, 23-07-24, BR, Added Max Packet Size property to allow the size of a single packet to be altered by the user
8, 1.1, 30-07-24, BR, Resolved ESP compile error due to missing return and added TopicTooLong error
The MQTT component requires connection to a Network Comms component via the "Network Component" property, to provide the bridge for simulated TCP/IP communication.
The Network Comms component can then be linked to an embedded TCP/IP component to provide embedded TCP/IP support.
Here is a typical setup for using MQTT on a Raspberry Pi.
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
SCADA BBC TEMPERATURES
Publish
Raspberry Pi
Here we have an embedded Raspberry Pi project connected to an I2C Sensor, the sensor is sampled and the data is published to a MQTT server.
RPI3 MQTT IOT EBM016
ESP8266 Module
Here we have an embedded project using an ESP8266 wifi module, an analogue input is sampled and the data is published to a MQTT server.
MQTT IOT ESP8266
Subscribe
ESP8266 Module
Here we subscribe to a topic and receive it back into Flowcode embedded using an ESP8266 module.
Subscribe ESP8266 MQTT
Flowcode App Developer
Here we subscribe to a topic and receive it back into Flowcode App Developer.
Subscribe App Developer MQTT
Making your own Raspberry Pi based MQTT Broker
Click here for instructions on creating your own Raspberry Pi MQTT Broker.
Connect
Connect
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
ConnectTo
ConnectTo
Connect to a variable MQTT Server, overriding the Host and Port properties. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
- STRING Host
- UINT Port
- STRING ClientID
Client identifier name - must be unique on server
Disconnect
Disconnect
Disconnects from the MQTT server and the network
ErrorAsString
ErrorAsString
- BYTE Error
- STRING Return
GetPayload
GetPayload
Get the Payload of the last received (Read) packet. Returns the number of bytes for the Payload
- STRING Payload
- BYTE Size
Byte count the Payload buffer
GetTopic
GetTopic
Get the Topic of the last received (Read) packet. Returns the number of bytes for the Topic
- STRING Topic
- BYTE Size
Byte count the Topic buffer
LastError
LastError
Returns the last error
Ping
Ping
Ping packet is sent to the Server and checks for a reply. Returns non-zero value if successful
Publish
Publish
Publish data to the server (broker) Returns non-zero if successful
- STRING Topic
- STRING Payload
Read
Read
Read incoming data. Returns non-zero if packet received. Use GetTopic and GetPayload to read the contents.
Subscribe
Subscribe
Subscribe to a Topic. Must be Connected first Returns non-zero if successful
- STRING Topic
Unsubscribe
Unsubscribe
Unsubscribe from a Topic. Must be Connected first Returns non-zero if successful
- STRING Topic
LinkTo
Host
Address of MQTT Broker Can be an IP Address or URL (URL only supported by some hardware platforms)
Port
Port used by MQTT Broker Default 1883 for unencrypted access and 8883 for encrypted access.
Client identifier
Client identifier (Maximum length 20 characters) Must be unique to the broker.
Network Timeout
Maximum time in mS to wait for network responses
Read Timeout
Amount of time in ms to wait for incoming messages.
Keep Alive
The Keep Alive is the maximum time interval that is permitted to elapse between the point at which the Client finishes transmitting one Control Packet and the point it starts sending the next, measured in seconds.
Authentication
Selects if the broker is open or if the broker requires a username and password.
Max Packet Size
Sets the number of bytes that can be sent and received in a single packet. A single packet consists of 4 header bytes, plus the topic and payload string data.
Please click here to download the component source project: FC_Comp_Source_MQTT_Client.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MQTT_Client.fcfx
