| Author
Matrix TSL
| Version
2.0
| Category
Comms: Interface
MULTIUART component
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
Please click here to download the component source project: FC_Comp_Source_MULTIUART.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MULTIUART.fcfx
Simple test program
CheckRx
CheckRx
| Returns the number of received bytes held in queue for the selected channel.
- BYTE
UART
| UART Index Range: 0-3
- BYTE
CheckTx
CheckTx
| Returns the number of bytes held in the transmit queue for the selected channel.
- BYTE
UART
- BYTE
| Activates the SPI peripheral and claims control over the I/O pins.
ReceiveByte
ReceiveByte
| Returns the first received byte held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
- BYTE
UART
- BYTE
ReceiveString
ReceiveString
| Returns a string of received bytes held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
- BYTE
UART
- BYTE
NumBytes
- STRING
SetBaud
SetBaud
| Adds a byte to the transmit queue for the selected channel.
- BYTE
UART
- BYTE
Baud
| 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200
TransmitByte
TransmitByte
- BYTE
UART
- BYTE
Data
TransmitString
TransmitString
- BYTE
UART
- STRING
Data
Bus Settings
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MOSI Remap Pin
| Select which the target pin to assign the MOSI hardware pin functionality.
MISO
MISO Remap Pin
| Select which the target pin to assign the MISO hardware pin functionality.
CLK
CLK Remap Pin
| Select which the target pin to assign the CLK hardware pin functionality.
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
| Label used to identify the component on the panel.
API
