| Author
Matrix Ltd
| Version
2.0
| Category
Graphical Library
Touch Screen (FT6X06) component
Low level routines for controlling or interacting with the FT6X06 touch screen controller IC found on a lot of common capacitive touch screen products. Also compatible with FT6x36 touch screen controller IC.
11, 1.0, 26-07-24, BR, Removed ghost greay square connection line
An example of how to sample read a capacitive touch display overlay using the component.
FT6X06 Demo
| Activates the SPI peripheral and claims control over the I/O pins.
ReadCoord
ReadCoord
| Reads a coordinate returned from the Sample Sensor macro. Coordinate is scaled to the X/Y Pixel bounds specified.
- BYTE
Coordinate
| 0 = X, 1 = Y, 2 = Pressure
- BYTE
Index
| Touch Index Range: 0 - 1
- UINT
SampleSensor
SampleSensor
| Reads the touch controller and returns true if there is currently a touch in progress. The touch coordinates can be read using the ReadCoord macro. Return 0 = No Touch, 1 = Single touch detected, 2 = Two touch points detected
- BYTE
SetOrientation
SetOrientation
| Allows the orientation to be overridden.
- BYTE
Orientation
| Range: 0 - 3
LinkTo
Bus Settings
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
Configuration
Apply Scaling
X Pixel
Y Pixel
Flip X
Flip Y
| Label used to identify the component on the panel.
Enable Interrupt
Interrupt Macro
| Macro called when the simulated display fires an interrupt.
Simulate Comms
| Allows the I2C communications to be simulated and piped through an API to real world hardware.
Please click here to download the component source project: FC_Comp_Source_TouchScreen_FT6X36.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TouchScreen_FT6X36.fcfx
