Component: Running Average 16-bit (Calculation)
Category Calculation
Running Average 16-bit component
Allows a value from a sensor to be averaged out filtering out high frequencies and removing noise. Running average means we have a variable that we maintain that on each pass will be 12.5% new value + 87.5% old value for example at a ratio of 8.
Filter
Filter
Performs the filtering function, passing in the latest sampled value and outputting the latest filtered value.
- INT Value
- INT Return
SetFilterRatio
SetFilterRatio
Sets the amount of input that makes it into each output. 8 would be 12.5% new and 87.5% old. Can be anything but recommended to use a power of 2 for efficiency.
- UINT Ratio
Number of samples to divide the new value down by, e.g. 8 = 12.5%
SetFilterValue
SetFilterValue
Sets the absolute value of the filter value i.e. for setting the initial state.
- INT Val
Please click here to download the component source project: FC_Comp_Source_RunningAverage.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_RunningAverage.fcfx
