| Author
Matrix TSL
| Version
1.0
| Category
General Output
PWM 16CH 12Bit (PCA9685) component
The PCA9685 is an I²C-bus controlled 16-channel LED controller optimized for Red/Green/Blue/Amber (RGBA) color backlighting or Servo motor applications. Each output has its own 12-bit resolution (4096 steps) fixed frequency individual PWM controller that operates at a programmable frequency from a typical of 24 Hz to 1526 Hz. All outputs are set to the same PWM frequency. Up to 64 devices can be chained together on a single I²C-bus to provide up to 1024 individual PWM outputs.
Please click here to download the component source project: FC_Comp_Source_PCA9685_16_Channel_PWM.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_PCA9685_16_Channel_PWM.fcfx
GetClockFrequency
GetClockFrequency
| Returns the current clock frequency
- ULONG
| Sets up the I2C ready for communications to begin
Reset
Reset
| Sends a reset command to the PCA9685 chip over I2C
SetAddress
SetAddress
| Allows a different I2C address to be specified allowing one component to control multiple PCA9685 modules.
- BYTE
Address
| Range: 0x40 - 0x7F
SetClockFrequency
SetClockFrequency
| Sets the current clock frequency, used for things like calculating the PWM frequency and Microsecond duty.
- ULONG
Clock
SetExternalClock
SetExternalClock
| Sets EXTCLK pin to use the external clock
- BYTE
Prescale
| External Clock Prescaler - Range: 3-255
SetOutputMode
SetOutputMode
| Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode.
- BOOL
Mode
| 0=OpenDrain, 1=Push/Pull
SetPWM
SetPWM
| Sets the PWM output of one of the PCA9685 pins
- BYTE
Output
| One of the PWM output pins - Range: 0 to 15
- UINT
On
| At what point in the 4096-part cycle to turn the PWM output ON
- UINT
Off
| At what point in the 4096-part cycle to turn the PWM output OFF
SetPWMFrequency
SetPWMFrequency
| Sets the PWM frequency for the entire chip, up to approx 1.6 KHz
- FLOAT
Frequency
| Floating point frequency that we will attempt to match
SetPin
SetPin
| Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on.
- BYTE
Output
- UINT
Duty
| The number of ticks out of 4096 to be active
- BOOL
Invert
| 0=Normal, 1=Inverted
Sleep
Sleep
| Puts the module into Sleep mode
WakeUp
WakeUp
| Wakes the module from Sleep mode
WriteMicroseconds
WriteMicroseconds
| Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise
- BYTE
Output
- UINT
Microseconds
| The number of Microseconds to turn the PWM output ON
Address
| Module I2C Address. This setting can be overridden using the SetAddress component macro.
Output Mode
| Sets the output mode of the PCA9685 to either open drain or push pull. Warning: LEDs with integrated zener diodes should only be driven in open drain mode. Can be overridden using the SetOutputMode component macro.
Clock Type
| Configures the input clock source to the module.
Clock Frequency
| Frequency of the module. Internal oscillator defaults to 250000000 or 25MHz but can actually be anywhere from 23 to 27MHz. External clock frequency can be specified here up to a max value of 50000000 or 50MHz. This setting can be overridden using the SetClockFrequency component macro.
Prescaler
| External Clock Prescaler Range: 3 to 255
Target PWM Frequency
| The ideal PWM frequency we would like to generate on the output pins. Servo motors require an output frequency around 50Hz. LEDs require a mugh higher output frequency to avoid visible flicker.
Actual PWM Frequency
| The calculated actual PWM frequency available using the Clock Frequency and Prescaler
PWM Resolution
| Number of microseconds the PWM output can resolve to
I2C Communications
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
