Component: Thermistor Using Beta (Environmental)
Category Environmental
Thermistor Using Beta component
ReadTemperature
ReadTemperature
- BOOL TempFormat
0 = Centigrade, 1 = Fahrenheit
- FLOAT Return
ReadThermistorValue
ReadThermistorValue
- FLOAT Return
Themistor
Ohms Value at 25C
Thermistor resistance at 25C is usually found on the thermistor datasheet. If you have a 10K thermistor, that that will be the value at 25C
Beta Value
Beta value is usually found on the thermistor datasheet
Fixed Resistor
Ohms Value
Value of pullup or pulldown fixed resistor in ohms
Resistor Biasing
Pullup - Fixed resistor is connected to + of the supply Pulldown - Fixed resistor is connected to 0V of the supply
ADC
VRef voltage
VRef option
Conversion speed
Acquisition cycles
Bit Depth
Temperature
Offset x 100
+/- x100 Enter temperature offset x 100 For example, temperature measured with an accurate thermometer is 22.0. Returned is 23.4, which is 1.4 degrees too high. For offset enter -140.
OffSet
Result Decimal Places
Number of decimal places (0 to 4) for temperaure results
Highest Temperature
Lowest Temperature
Temperature Units
Please click here to download the component source project: FC_Comp_Source_Thermistor_Using_Beta.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Thermistor_Using_Beta.fcfx
