Component: Console Writer (Indicators)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 2.0
Category Indicators
Console Writer component
A simple component to aid in creating and wiriting data to a console tab. Allows text to be coloured and automatically appended with a timestamp.
Version information
4, 2.0, 02-07-24, BR, Added a load more functionality to the component related to cursor control
A basic example using two circular knobs to simulate data e.g., temperature. Both xy chart and Console, log the data.
Logging Example
AddString
AddString
Adds text string to the end of the console window.
- STRING Data
AddStringAtCursor
AddStringAtCursor
Adds text string to the current cursor position.
- STRING Data
Clear
Clear
Clears the contents of the console tab.
ClearFromCursorToLineEnd
Clears the contents of the current selected line from the cursor position to the end of the line.
ClearFromLineStartToCursor
Clears the contents of the current selected line from the start of the line to the cursor position. Sets the Column position to 0.
ClearLine
ClearLine
Clears all data from a specific line. Automatically sets the cursor to the start of the line.
- LONG Line
Line number, -1 for the last line.
ClearXCharsFromCursorPosition
Clears the specified number of characters starting from the cursor position.
- UINT CharacterCount
Number of characters to remove
CountLines
CountLines
Counts the number of lines in the console.
- ULONG Return
GetTextLine
GetTextLine
Gets the string data from a specific line in the console.
- LONG Line
- STRING Return
SetColour
SetColour
Allows for full RGB colour selection
- BYTE R
Colour channel, Range: 0-255
- BYTE G
- BYTE B
SetColourIdx
SetColourIdx
Sets the text colour from the properties selection of colours.
- BYTE Index
Range: 0-3
SetCursorPosition
SetCursorPosition
Sets the position of the cursor
- LONG Column
Character position along the line, starting from 0
- LONG Line
SetTextLine
SetTextLine
Sets the string data from a specific line in the console.
- LONG Line
- STRING Data
ShowConsole
ShowConsole
Pops up the console window and shows the correct tab.
Console Name
Textual name of the console shown as the tab name at the top of the console window.
Colour 0
Used to define a colour channel referenced by the SetColourIdx component macro call.
Colour 1
Colour 2
Colour 3
New Line After Data
Automatically append a newline character after any data has been written to the console using the AddString component macro.
Clear On Sim Start
Automatically clear the console tab when the simulation is started.
Add Timestamp
Automatically adds a timestamp to the console after a newline character has been received.
Timestamp
Date Format
Specifies the format of the date string. No - "DD/MM/YY" Yes - "MM/DD/YY"
Time Separator
Characters that are used in between the time digits
Date Separator
Characters that are used in between the date digits
TimeStamp Separator
Characters that are used between the time and date strings when returning a full time stamp.
Override Colour
Overrides the current selected colour when writing the timestamp.
Timestamp Colour
Defines the colour of the time stamp text
Please click here to download the component source project: FC_Comp_Source_ConsoleWriter.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ConsoleWriter.fcfx
