| Author
Matrix Ltd
| Version
12.0
| Category
Alphanumeric
LCD (Grove - I2C) component
Standard alphanumeric LCD based on the Grove I2C LCD module with RGB backlight.
12, 12.0, 22-08-24, MW, Fixed bug within SetReg that causes compile to fail with ESP32
BacklightControl
BacklightControl
- BYTE
Red
- BYTE
Green
- BYTE
Blue
Clear
Clear
ClearLine
ClearLine
- BYTE
Line
Command
Command
| Use this method/macro to send a specific command to the LCD. Refer to the Matrix Multimedia EB006 datasheet for a list of supported instructions. For Non-Matrix LCD's refer to the manufacturers datasheet.
- BYTE
instruction
Cursor
Cursor
| Moves the cursor on the LCD Display
- BYTE
x
- BYTE
y
PrintAscii
PrintAscii
| Takes the ascii value for a character and prints the character
- BYTE
character
PrintFloat
PrintFloat
| Print a Float number rounded up to a specified amount of decimal places.
- FLOAT
Number
| Enter the number or variable to print to the LCD
- BYTE
DecimalPlaces
| Enter how many decimal places to round up to (1 - 6)
PrintFormattedNumber
| Will allow you to print a number up to 32-bits with signed or unsigned formatting. Signed = -2147483648 to 2147483647 Unsigned = 0 to 4294967295
- ULONG
Number
- BOOL
Format
| 0=Signed, 1=Unsigned
| Allows you to print a number. This is limited to a signed-INT, -32768 to 32767
- INT
Number
PrintString
PrintString
- STRING
Text
RAMWrite
RAMWrite
| Modifies the internal memory of the LCD to allow for up to 8 customised characters to be created and stored in the device memory
- BYTE
Index
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
ScrollDisplay
| Scrolls the display left or right by a number of given positions.
- BYTE
position
- BYTE
direction
SetI2CAddress
SetI2CAddress
| Allows the I2C device address to be dynamically changed in software without having to re-compile. Can be called before the first Start macro or at any point after.
- BYTE
Address
| New I2C Device Address excluding R/W bit - Range 0 - 127
Start
Start
| Startup routine required by the hardware device.
I2C Config
LCD Address
RGB Address
Alt RGB Address
| Channel selection
Baud Select
| Baud rate option selector
| Baud rate to be used
Stop Delay
SDA
SCL
LCD Configuration
LCD Backlight Type
Rows
Columns
Component Label
Component Label Scale
Text Colour
| Colour of the font characters drawn on the display
Text Background
Display Background
Simulate Comms
| Used to drive the comms durig simulation which can be used to: Data Recorder waveform generation Console Logging Data Injector to redirect the data e.g. to a SCADA slave connected to the physical hardware
| Selects if the component pin connections are automatically generated on the data recorder window or not. Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion. No: Do not show the pin signals on the data recorder window.
API
| Specifies the injector component on the panel to interact with to provide comms simulation.
Please click here to download the component source project: FC_Comp_Source_LCD_Grove_I2C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Grove_I2C.fcfx
