Component: IO Expander (MCP23017) (MCP23017) (General Input)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 5.5
Category General Input
IO Expander (MCP23017) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins.
Version information
5, 5.0, 25-04-25, MW, Added two extra functions:ConfigureIOC & ReadINTFlag
ConfigureIOC
ConfigureIOC
Configures theinterupts for the two ports. Disabled on all pins by default.
- BYTE PortA
Port A IOC sent as an 8-bit value (0 - 255), 0 = Disabled, 1 = Enabled
- BYTE PortB
Port B IOC sent as an 8-bit value (0 - 255), 0 = Disabled, 1 = Enabled
ConfigureInversion
ConfigureInversion
Configures the pin inversion for the two ports. Disabled on all pins by default.
- BYTE PortA
Port A inversion sent as an 8-bit value (0 - 255), 0 = Disabled, 1 = Enabled
- BYTE PortB
Port B inversion sent as an 8-bit value (0 - 255), 0 = Disabled, 1 = Enabled
ConfigurePullups
ConfigurePullups
Configures the pullups for the two ports. Disabled on all pins by default.
- BYTE PortA
Port A pull ups sent as an 8-bit value (0 - 255), 0 = Disabled, 1 = Enabled
- BYTE PortB
Port B pull ups sent as an 8-bit value (0 - 255), 0 = Disabled, 1 = Enabled
ReadINTFlag
ReadINTFlag
Reads a value of the INT flag with a mask. E.g if reading the whole port and the value is 18 = 0b00010010 then pins 4 and 1 triggered the interrupt INT flags are cleared by reading the associated ports.
- BYTE Port
0=PortA, 1=PortB
- BYTE Mask
Allows Interrupt flag bits to be read without effecting other bits, 255 = Read full interrupt flag register.
ReadPort
ReadPort
Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
- BYTE Port
0=PortA, 1=PortB
- BYTE Mask
Allows port bits to be modified without effecting other bits, 255 = write full port.
ReadPortPin
ReadPortPin
Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
- BYTE Port
0=PortA, 1=PortB
- BYTE Pin
Port pin to read. Range: 0-7
ReadRegister
ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
- BYTE Address
Register address to write to. Range: 0-15
SetAddress
SetAddress
Allows the slave address to be overridden to allow multiple modules to be controlled using a single component.
- BYTE Address
Range: 0-7
WritePort
WritePort
Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
- BYTE Port
0=PortA, 1=PortB
- BYTE Mask
- BYTE Value
Value to write. Range 0-255
WritePortPin
WritePortPin
Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
- BYTE Port
0=PortA, 1=PortB
- BYTE Pin
- BYTE Value
Value to output on the selected pin. Range: 0-1
WriteRegister
WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
- BYTE Address
- BYTE Value
Value to write. Range: 0-255
I²C Communications
External Address
Selects the value of the three address pins for the MCP23S17.
Channel selection
Stop Delay
Baud Select
Baud rate to be used
SDA
SCL
Use Reset
API
Please click here to download the component source project: FC_Comp_Source_MCP23017.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP23017.fcfx
