Component: Bluetooth BLE (ESP32 SPP Client) (Wireless)
Revision as of 14:36, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Category Wireless
Bluetooth BLE (ESP32 SPP Client) component
Bluetooth BLE client component designed to run on a ESP32 providing GATT SPP functionality. Designed to scan for and connect to an existing Bluetooth BLE GATT SPP server. BT BLE functionality must be switched on via the sdkconfig file.
CheckConnectionStatus
Checks to see if the Bluetooth device is connected. Returns 1 if connected.
- BOOL Return
ConnectToDevice
ConnectToDevice
Manually connect to the specified discovered device. Returns true if the device connected successfully.
- BYTE index
- BOOL Return
DisconnectFromDevice
Manually disconnect from the connected device
GetDiscoveredDeviceCount
Returns the number of discovered devices.
GetDiscoveredDeviceMAC
Gets the 6 Byte MAC address of the discovered device at the selected index
- BYTE index
- BYTE MAC
6-byte Array to return the MAC address into
GetDiscoveredDeviceName
Gets the friendly name of the discovered device at the selected index
- BYTE index
- STRING Return
Starts up the Bluetooth communications SPP service.
ReceiveArray
ReceiveArray
Attempts to receive an array of bytes from the bluetooth serial port. Returns the number of bytes received.
- BYTE Data
Buffer to place received data into
- UINT MaxBytes
Max number of bytes to try and read within the time
- UINT Timeout
Number of ms to wait for incoming data
ReceiveByte
ReceiveByte
Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured
- UINT Timeout
ReceiveCount
ReceiveCount
Collects the number of bytes currently stored in the receive buffer.
ReceiveINTArray
ReceiveINTArray
Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT Data
Array to store the incoming data
- BYTE NumValues
Maximum number of values to try and receive
- BOOL MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE Timeout
Max amount of time in ms to wait between bytes
ReceiveString
ReceiveString
Attempts to receive a string of characters from the Bluetooth SPP. Terminates on timeout, on receiving the MaxBytes or on receiving a '\n' character
- UINT MaxBytes
- UINT Timeout
- STRING Return
SendArray
SendArray
Sends a byte to the Bluetooth serial connection
- BYTE Data
Data Array to send
- UINT NumBytes
Number of bytes to send
SendByte
SendByte
- BYTE Data
SendINTArray
SendINTArray
Sends an array of 16-bit integers to the Bluetooth serial connection
- UINT Data
Data Array to send
- BYTE NumValues
- BOOL MSBFirst
SendString
SendString
Sends a string to the Bluetooth serial connection
- STRING Data
Data Array to send
Uninitialise
Uninitialise
Shots down the Bluetooth communications SPP service.
Receive Buffer
Configures the size of the receive buffer in bytes to store incoming data until we are ready to receive it.
Max Discovered Devices
Maximum number of devices that can be detected.
Filter By UUID
Allows the scan results to be filtered to a specific UUID in the advertisement data
Service UUID
16-bit value that identifies the custom “Simple SPP” service so scanners know the device supports that feature.
Characteristic UUID
16-bit value that describes the single characteristic that carries the serial-like data flow (reads, writes, notifications).
Auto Connect On Match
Auto connect to the first device we find with a matching UUID
Data Receive Interrupt
Verbose Debug
When enabled debug messages will be placed onto UART CH1 which is generally connected to via a Serial to USB IC to pipe messages back to the host PC.
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
Baud rate passed to the COM port to control the rate of data.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Client.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_ESP32_BLE_GATT_SPP_Client.fcfx
