Component: GLCD QR Code Generator (Graphical Library)
Revision as of 14:35, 13 July 2026 by SteveT (talk | contribs) (Text replacement - "style="background-color:#EAE1EA; color:#4B008D;"" to "class="mtx-class-propfolder"")
Version 2.2
Category Graphical Library
GLCD QR Code Generator component
A component to generate QR codes for displaying on a GLCD.
Here a simple example showing a QR code being generated on a display.
The size of the QR code in blocks is set using the QR version component property.
The size in pixels of each block is set using the BlockSize function parameter.
QR Demo
DrawQRCode
DrawQRCode
Generates and displays the QR code. Returns the detected data type, 0=Numeric, 1=Alphanumeric, 2=Byte, 3=DataTooLongError
- STRING Data
QR Code data to embed, e.g. URL, Message or Phone number
- UINT X
Left hand side coordinate to start drawing
- UINT Y
Right hand side coordinate to start drawing
- BYTE BlockSize
The size of each segment in pixels. Default 1
LinkTo
ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
InvertColour
QR Settings
QR Version
Sets the size of the QR code in graphical squares
Error Correction
Sets the level of error correction available
Max Chars Numeric
The maximum number of character bytes that can be stored in the QR code based on the selected QR settings. Range of data to qualify is characters '0' - '9'
Max Chars Alphanumeric
The maximum number of character bytes that can be stored in the QR code based on the selected QR settings. Range of data to qualify is characters '0' - '9' / 'A' - 'Z' / ' ' / '$' / '%' / '*' / '+' / '-' / '.' / '/' / ':'
Max Chars Byte
The maximum number of character bytes that can be stored in the QR code based on the selected QR settings. Range of data is ASCII codes 1 - 254
Please click here to download the component source project: FC_Comp_Source_Lib_QRCode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Lib_QRCode.fcfx
